06-05-2019, 07:15 PM   #1
ZombieArmy's Avatar
What used Tripod head should I get?
Hi guys! My pan tripod head that came with my tripod I got a few years ago died on me and I don't really want to fix it because I don't really trust it. The main part of the tripod however is rock solid and I love it so I want to get a "new" head for it but I have no clue what's good. I do some minor video stuff, but it's mostly for photo work so the type of head doesn't particularly matter either, I just need something solid that's easy to get on and off and will hold my KP fine.
My price range is around 50-100, though lower would be better for me.
06-05-2019, 07:54 PM   #2
jlstrawman's Avatar
Best tripod heads $50-100 - Google Search
06-05-2019, 08:00 PM   #3
ZombieArmy's Avatar
QuoteOriginally posted by jlstrawman Quote
Was looking for some personal favorites from you guys.
06-05-2019, 08:22 PM   #4
luftfluss's Avatar
I've been using this for a few years Slik SH-705E 3-Way Pan/Tilt Head 615-335 B&H Photo Video
I'm a pretty basic tripod user, though - I don't try to pan along with moving subjects or anything like that. The Slik has operated smoothly and perfectly with my K-3 II + battery grip + lenses up to 3kg.
06-06-2019, 05:18 AM - 1 Like   #5
TaoMaas's Avatar
It's kinda big and clunky by today's standards, but I've used a Bogen/Manfrotto 3047 pan/tilt head for years. It takes the hexagonal quick-release plates and is sturdy enough to handle pretty much anything you'd care to mount on it. But best of all...they're cheap these days. With a little looking, you could probably pick one up for $20-30 on Ebay.
06-06-2019, 05:25 AM   #6
bdery's Avatar
I really like my old Vanguard head, bang for the buck it's excellent. Recently I've been using Sirui heads quite a lot, they do not reinvent the wheel but work exceedingly well. they have all the same perks and flaws as other brands at a lower price. Take a look at the K10x head which, despite being the smallest in their K line, is strong enough for just about anything I've thrown at it.
06-06-2019, 06:17 AM   #7
MossyRocks's Avatar
I second getting a Manfrotto 3047 and yes they can be had for cheap. I paid $35 for one at a brick and mortar this past winter since I went and built a big super heavy duty tripod for astrophotography and needed a head for it. I liked the head so much better than the little ballhead on my regular tripod that I now move that old head between them as needed. I should probably see if the store still has a few more rolling around and just go buy them so I don't have to keep moving it from tripod to tripod.
06-06-2019, 07:30 AM   #8
My Favorite is the RRS BH-55 ball head, but that is why out of your stated price range.
On another, lighter weight tripod I use a Oben BE-117T ball head.It works well for photos and it has panning capability
I use a K50 and K3 on regularly .
The only thing I don't like about it is the position of the slot for tilting, I'm right handed and tilting up steeply requires the lock knob to be on the left.
A minor thing, really. Runs about $90 at B&H
06-06-2019, 10:40 AM   #9
bdery's Avatar
One thing that should always come up when discussing tripod heads is plate compatibility.
Manfrotto is a big name and they have their own plates, which are only compatible with their heads and a few others who want to follow them.
A few "entry-level" companies(for lack of a better term) use proprietary and
Almost everyone else (I've read the number 85% but can't vouch for it) use Arca-Swiss. This means that you can swap heads, plates, get a cheap plate from eBay, use systems like Peak Design's Capture Clip, use your friend's tripod, without ever worrying that your plate and head will fit.
To me, using an Arca-Swiss compatible system isn't even a question.
06-06-2019, 11:07 AM   #10
Seeker of Knowledge
aslyfox's Avatar
the OP might want to check this area of the forums out:
Tripod Heads - Pentax Camera Accessory Review Database
06-06-2019, 11:36 AM   #11
Otis Memorial Pentaxian
QuoteOriginally posted by ZombieArmy Quote
QuoteOriginally posted by luftfluss Quote
I have the same head that I use for video or for other cases where a ball head is cumbersome. Addendum: Panning action is fairly smooth, but requires a measured touch.
If I were in the market for a tilt-pan head, I would likely also consider:
https://www.bhphotovideo.com/c/product/221363-REG/Slik_615_700_700DX_3_Way_Pan.html
...has higher capacity and more substantial base for smoother pan.
06-06-2019, 11:48 AM   #12
I tend to agree, but will note that many proprietary QR plates as well as traditional non-QR platform (1/4-20 screw only) may be securely mated to an Arca-Swiss clamp.
For a 2-way pan-tilt with Arca-Swiss (has flip-to-vertical hinge), this model may be worth considering:
Field Optics Research FPH-200 Pan Head FPH-200 B&H Photo Video
I use this light Arca-Swiss clamp mated to my Manfrotto MH-494 Mini Ball Head (simple platform) to add QR support:
https://www.bhphotovideo.com/c/product/1028649-REG/desmond_dac_x1_level_50mm...lamp_with.html
06-06-2019, 12:00 PM   #13
I have a Sirui K-30x that is in excellent condition that I've been thinking about selling since I upgraded to an Acratech.
I'd probably sell the Sirui for $80+shipping, if you're interested, PM me.
06-06-2019, 04:43 PM   #14
monochrome's Avatar
QuoteOriginally posted by TaoMaas Quote
I was about to recommend this very head. Used it for years until I switched to ball heads. The QR plate is very secure, but unusual - I don’t think many other heads use it. I have a useless extra plate laying around somewhere because I forgot to sell it with the pan head.
06-06-2019, 07:43 PM   #15
ramseybuckeye's Avatar
I've used an Induro SA-23 Ballhead for about ten years, but I did replace the quick release system to be arca compatible a few years ago. I have 3 smaller Mefoto tripods that are arca compatible too. One oif those had a mini arca type system, I replaced that with the standard size also. I have a friend that is a gunsmith, he did a little machining on it to make it work. Now I have multiple tripods and several plates that are all interchangeable. The Induro head is very solid, but probably replaced by now.
head, tripod, tripod head
Need help figuring out tripod and tripod head for k3 II Infinite Ascension Troubleshooting and Beginner Help 32 03-27-2018 07:05 PM
Should I get the 28-105, or, should I just get the 24-70? VoiceOfReason Pentax SLR Lens Discussion 22 05-20-2016 10:20 AM
Video Head (tripod head) Question... littledrawe Pentax Camera and Field Accessories 3 04-23-2012 12:14 AM
Tripod Head - Can I add Rotation to my current ball head claimed4all Pentax Camera and Field Accessories 5 10-11-2011 09:34 AM
Gear head vs. 3-way pan tripod head heatherslightbox Pentax Camera and Field Accessories 3 05-22-2009 06:54 PM
All times are GMT -7. The time now is 11:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
