10-11-2008, 05:56 PM   #1
Using AF-360 wirelessly
I just picked up a 360 and was interested in using it wirelessly. I have followed the instructions, but it seems that the flash only worked in conjunction with the on camera flash, is this correct? Or can I use it as a slave without having to use the on camera flash?
10-11-2008, 06:30 PM   #2
I am 99% sure it only works with the onboard flash. Someone certainly will correct me if I am wrong.
10-11-2008, 06:32 PM   #3
spyglass's Avatar
You can trigger your 360 via the on board flash (your camera should be able to switch the on board flash function to trigger mode only - where the on board flash will not affect the photo, or in standard default mode - where the on board flash will affect the photo). Basically your 360, when set to slave, is looking for trigger information sent by the on board flash or a flash mounted on the camera hot shoe.
If you have a second 360 you can place one on the hot shoe (or cable remoted) set as the master,and the other can be remote and wireless set as the slave. Basically the term wireless is a bit misleading. In todays world we think of wireless as a radio function. It should be called flash linked (as used in yuor arangement) & cable linked if joined together via wire means.
10-11-2008, 07:01 PM   #4
QuoteOriginally posted by spyglass Quote
Since the OP didn't mention which camera model they have, I thought I'd better mention that the K100 cannot act as a wireless flash controller. The K200 however, can.
10-11-2008, 07:05 PM   #5
Excellent answer. That is what I though but I just wanted it confirmed, so I don't waste time trying to get it to do something it is not capable of. I still am very happy with the flash.
camera, flash, tripod, wirelessly
Using multiple flashes wirelessly jake14mw Flashes, Lighting, and Studio 16 09-02-2010 10:54 AM
Old Ricoh Safe to Use Wirelessly? wshi Pentax Camera and Field Accessories 3 05-17-2010 06:15 PM
Inventive ways to trigger 360 wirelessly outdoors? dbphotography Pentax Camera and Field Accessories 10 06-20-2009 05:20 PM
Can I fire the Pentax AF-360 FGZ wirelessly without triggering on-camera flash? jacksonpritt Flashes, Lighting, and Studio 17 04-21-2009 09:52 AM
Can an AF-540 wirelessly control two AF-360? Buddha Jones Pentax Camera and Field Accessories 13 04-03-2008 12:12 AM
All times are GMT -7. The time now is 04:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
