09-01-2019, 01:23 PM   #1
Could you tell me what this is?
Hello, I'm wondering what this old accessory is. I got it from an ancient camera box. It looks like a tool that aids focusing with manual camera. Is this? Can I play with it with digital camera? It's very well made and elegant.
09-01-2019, 01:25 PM   #2
sergysergy's Avatar
You can attach it to the camera viewfinder. I think they were meant to be used with older models but they might work with more modern bodies
09-01-2019, 01:29 PM   #3
This is an old angle finder. I don't know if this will fit at a DSLR
09-01-2019, 01:56 PM   #4
Then soft rubber eyepiece on most of the digital bodies slide straight up and off the camera.
This unit may slide onto the same slots.
The knurled ring at the top of this unit would allow you to adjust the focus so that the markings inside the viewfinder are sharp. It does nothing to focus the image, you still do that with the lens.
Useful on a tripod, or other fixed camera location.
It looks like it's an older version of this device
09-01-2019, 02:06 PM   #5
Otis Memorial Pentaxian
It is called a refconverter and looks to be the version that will fit M42 and K-series Pentax film SLRs. They are handy for right-angle viewing and also have provision for diopter adjustment. Given the Asahi branding, it is highly unlikely that it will fit M-series or later bodies. FWIW, there is a similar eyepiece magnifier too.
09-01-2019, 02:24 PM   #6
RobA_Oz's Avatar
You can make it fit a Pentax DSLR, but only by widening the gap between the slides that fit into the camera viewfinder. I have one that has been modified (filed down a bit roughly, and not by me) and it works. Be prepared, though, to deal with a left-to-right reversed image. Ultimately, I couldn’t, so I searched around to find a later refconverter, which was much easier to use, though not cheap. Then, of course, along came the K-3 and FLUcard, and then the K-1, so I haven’t used either for a long time.
09-02-2019, 05:57 AM - 1 Like   #7
Lowell Goudge's Avatar
Even easier to fit, take the viewfinder cover for a dslr remove the mount from the right angle finder and screw the viewfinder cover with appropriate holes in this place
10-03-2019, 10:48 PM   #8
I cannot add much to what has already been said, but it is very useful for macro or even portrait work when using older cameras such as my Spotmatic. Here is a couple of photos of the one that I have.
IPad mini 2  Photo
IPad mini 2  Photo
camera, tripod
Could you please tell me the mount of this lens mars76 Pentax SLR Lens Discussion 7 12-03-2018 12:50 PM
Could someone tell me why? Rene` Pentax K-5 & K-5 II 20 07-10-2011 01:05 AM
could someone please tell me what this is? slip Pentax SLR Lens Discussion 10 04-12-2011 10:07 PM
Autofocus for manual lenes *could* be possible, read and tell me what you think konraDarnok Pentax News and Rumors 7 03-21-2008 10:31 PM
Lost my manual, could someone tell me strictlypentax Pentax SLR Lens Discussion 8 09-24-2007 12:45 PM
All times are GMT -7. The time now is 06:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
