09-12-2019, 07:57 AM - 1 Like   #1
ivanvernon's Avatar
Wanted: An effective writing pen
I need a writing product that will let me place an identifying mark on my camera memory cards. I simply need to associate each card with a specific camera. Generally I would just write a single letter: Z and D for the Pentax 645D and 645Z cameras, for example. The numerals 01, 1, 5, 3, 20, and 10 would do it for the 135 cameras, with each letter or numeral signifying the the specific camera with which each card is being used. This sounds like a really simple problem, but I cannot find anything to write with that is clear and permanent. Sharpies, lead pencil, ball point, even old-fashioned ink pens--none of these have worked for me. Some will not write all on the slick label of the cards, and others such as sharpies will write, but then quickly smudge and disappear. I will greatly appreciate any suggestions you can provide.
09-12-2019, 02:28 PM - 1 Like   #2
Sandy Hancock's Avatar
Interesting. I have never had an SD card out of the camera long enough for it to get mixed up with another camera, and as I usually format the card when I put it back in the camera it doesn't really matter which camera it goes into. The only card I have ever labelled (and that was recently) is the one with the file to push a K10D into DEBUG mode.
Others never take the SD card out, and use a cable to transfer files to the computer.
Another approach might be to use different size cards for different cameras. I use 128 MB cards in the 645Z and K-1's, 64 or 32's in the KP and GR III, and 16's in the Q.
09-12-2019, 03:16 PM   #3
ivanvernon's Avatar
Thank you Sandy.
09-12-2019, 06:47 PM   #4
White Out.
09-12-2019, 07:15 PM   #5
Kozlok's Avatar
Or buy different brand cards for each camera. A Sony for one, Samsung for the other, etc.
09-12-2019, 09:10 PM   #6
Otis Memorial Pentaxian
Get boxes and label them? For the cards themselves, you can assign volume names using your computer so that as a last resort, simply pop them into a reader.
09-12-2019, 10:56 PM   #7
ivanvernon's Avatar
Thanks for the idea. Actually, that is what I do now--assign names to each card that reflect the camera in which they are used. What I am seeking is a visual means of associating each card with its respective camera to avoid the necessity of popping every card in the computer card reader to identify it.
---------- Post added 09-13-19 at 02:00 AM ----------
QuoteOriginally posted by Kozlok Quote
Good idea, and what I am doing now as a de facto solution, but with two medium format cameras and five K-mount cameras and a brain and memory that are approaching 80 years of age, this solution does not always work. That is why I am seeking a visual labelling solution so that I can visually identify the card that is used by each different camera.
---------- Post added 09-13-19 at 02:02 AM ----------
QuoteOriginally posted by Auzzie-Phoenix Quote
White Out.
Thanks for the idea. I will check this out. There used to be white-out pens, but with the disappearance of typewriters I am unsure whether they are still available. I see a trip to Staples in my future!
09-12-2019, 11:24 PM   #8
How about the pens used to write on compact disks? If they still exist .
09-12-2019, 11:55 PM   #9
david94903's Avatar
QuoteOriginally posted by ivanvernon Quote
Interesting... I use Sharpies to number my SD cards and my batteries. Have not noticed the sharpie wearing off on the SD cards. But I typically handle them from the edge, so I'm rarely touching the flat surface with the writing.
I guess you could use some acrylic paint (i.e. Liquitex or similar) and a small brush to paint the numbers on the cards.
09-13-2019, 02:02 AM   #10
angerdan's Avatar
Use printable self-adhesive labels. Cut them half to reach the size.
You can write on them with a regular pallpoint pen. Or even print on them with your PC and printer
09-13-2019, 03:27 AM   #11
ivanvernon's Avatar
QuoteOriginally posted by angerdan Quote
Good idea, will try it.
---------- Post added 09-13-19 at 06:29 AM ----------
QuoteOriginally posted by david94903 Quote
I will try the sharpie again, maybe mine was not really a sharpie.
---------- Post added 09-13-19 at 06:30 AM ----------
QuoteOriginally posted by slartibartfast01 Quote
I do not know what kind of pens were used for the CDs, but will check this out too.
Thanks to everyone for all the ideas. I am sure one of these will work for me.
09-13-2019, 04:42 AM   #12
bdery's Avatar
If a label printer doesn't work (I'd print directly on it with a small font), just some white stickers meant to write on them, cut them to size and write.
I confess I'm surprised that a sharpie gets smudged.
09-13-2019, 05:40 AM   #13
ivanvernon's Avatar
I am trying the label approach, but will check out the sharpie again. Thank you for your response.
09-13-2019, 06:42 AM - 1 Like   #14
Kozlok's Avatar
The problem with paint or a label is something coming off and getting all over inside your SD slot. I wouldn’t do either of those.
Another choice would be to only remove one at a time, load them onto your computer, then put them back.
09-13-2019, 09:37 AM   #15
ivanvernon's Avatar
Thank you. Loading and unloading one at a time is what I have been trying (unsuccessfully) to do, but now it looks like the sharpie marking approach will work best.
NOTE TO ALL THE RESPONDERS:
Thanks everyone. I picked up a new package of sharpies, and they work. Don't quite know why I thought they did not work earlier. Thanks for all the responses and ideas.
camera, cameras, card, cards, computer, customer service, idea, letter, names, paint, pens, post, reader, ricoh imaging, sd, sharpie, sharpies, solution, suggestion, tripod
Orange Writing on Lenses BruceBanner Pentax SLR Lens Discussion 26 11-19-2018 10:34 PM
Different effective exposure from same settings on 2 DSRLs akptc Troubleshooting and Beginner Help 17 11-17-2018 01:00 PM
Penta k3 issue writing to card or card issue? Andrewlang Troubleshooting and Beginner Help 19 10-29-2018 06:27 PM
Videos on K-30: The camera records itself NOISILY writing to its SD card! aaaaugh! beebs Troubleshooting and Beginner Help 12 03-27-2018 01:58 PM
Marking (SD) cards. i.e. writing on them. Green_Manelishi Pentax Camera and Field Accessories 4 03-21-2009 06:22 PM
All times are GMT -7. The time now is 11:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
