Originally posted by dan.a.nesheim Is it still stable if you add a larger lens or is it to unstable with i.e. 24-70mm f2.8 or 70-200mm f2.8?
I'm guessing a lot will depend on your set up, weights and how it's configured. You'll notice from my image, how I always line up the clamp/lens along the longest axis of the Platypod. To be honest... mine's as solid as the surface I put it all on.
My ball head has a load capacity of 23kg, it weighs itself 850g with the clamp, the Platypod has a load capacity of 136Kg and weighs itself 368g.
So a K1 c/w Grip with battery is about 1.5kg, my heaviest lenses ("Lady Luck”(Pentax-A* 135mm F1.8), "Gorgeous Lady”(Pentax-A* 200mm) and “Duchess”(Pentax-A* 300mm F4.0) all come in around the 850g, so I'm all well within limits.
