Originally posted by barondla Good info. Does the Tenpa obstruct the articulated screen in waist level mode? May have to check out the Tenpa.
Thanks,
barondla
The issue with Tenpa is price, youch..
Originally posted by y0chang Yes with my glasses sometimes I don't see the corners of the frame well, the mod that I did actually means the lens isn't as recessed in the eye cup which helps. But I have to really strain to see the LCD data clearly. That is part of the reason why I wasn't in the mood to spend another 35 dollars in 2 years. It really helps though with shallow depth of field lenses though.
Yeah ok, might have to try that, I actually have my O-ME53 in a box, I think I tried putting on my KP and found it just give less clarity across the entire frame than with nothing so I took it off. I will have to retest again.
FWIW. my test went something like this;
Set up the camera on a tripod, have a flat target somewhere in the distance off centre slightly (so that you don't get the spot focus af point confirmation), I used/hung one of my kids drawings up for example, taped to a coat hanger, so that there was scenery behind it and not stuck on a wall (so like it was dangling in the air). In camera I took off all AF points and grid lines, made the screen look as blank as possible (when looking through the OVF). I then took 10 shots in quick succession with a wide aperture, f2 with the FA77 for example, with after each shot dialling the focus ring back so that things were blurry and I would have to refocus properly again each time. I timed how long it took me to take the 10 shots and then I went through the images and marked how many I got perfect focus with (1), almost perfect (2), ok (3), poor (4) and awful (5), so like a grade of 1-5). The Tenpa gave me something like a 7/10 perfect focus shots, without Tenpa it was more like 3-4 perfect shots, so I concluded it was definitely assisting. My timing of taking the 10 shots was also slightly quicker.
