Originally posted by BruceBanner Ultimately some of these suggestions can come from those that shoot casually. If you ever cover a full wedding from 10am - 1am you will understand the hesitation to have any kind of strapping mechanism around your waist.
Originally posted by BruceBanner A belt works well, and perhaps an investment into something like a better more classy cosyspeed and their pouches would be sufficient. Something I can unbuckle quickly and put on the ground to take the shot, place back on the hips afterwards and suffer the least amount of neck strain throughout the gig.
I had erroneously understood that you didn't want to go towards the full photo belt solution.
If you do, I urge you to look at Think Tank's modular belt system. I mentioned the Lens Changers and Speed Changer earlier, they also have a pad to attach a Spyder or Peak Design clip, plus a plethora of other accessories. They're the kind of stuff pros will use, and I have seen quite a few wedding photographers using them.
