Originally posted by Paul the Sunman It doesn't have to be one or the other.
True. But sometimes it is...
Originally posted by taktoon Weight of the tripod up to 2.5 kg without the head (prefer less).
That's not very strict. You can go well beyond the travel tripod range.
Originally posted by taktoon The problem that I have is that I won't be able to put my hands on it before buying and the specification on the paper and real life can be two different stories in case of a tripod.
True. And that's annoying. Stores only keep a few mainstream brands in many cases (the biggest store ni my area has probably 10 Manfrottos but not much else).
Many people like their 3 Legged Things. And most tripods will work perfectly when the conditions are not too difficult. AND I've personally taken superb 14 minutes exposures with a 40$ Dolica...
From my humble research, Sirui offers a lot of bang for your bucks. Oben are not too far behind also.
Knowing your weight limit and your height requirement is excellent. The last thing I'd try to decide is how you intend to use the tripod (after traveling by plane? Around the house? In cold weather?) etc). Then you will be able to narrow down your choices even more.
That being said, if you like the idea of the Winston, then by all means go for it!
