Hi, I need to get a cap and hood for a prime wide lens. Here where live its hard to get Pentax accessories. The lens in question is an old one, so 3rd party or second hand are also valid options. That means I will be buying from the internet - so i cannot check items beforehand. My specific needs would be a hood for 28mm / 30mm (FF DSLR) and the ability to keep it all the time in the lens (52mm diameter), so i would like to be able to put a cap inside de hood (would the cap also be 52mm? or less, say, 49mm?). This means Takumar hoods/caps are not an option. So, what else would you recommend? What kind of hoods out there have inside threads so to insert a cap or filter inside it? Also: Rubber or metal? Square or round? I prefer Pentax, but if not, what else?
Thanks for the opinions.
