Originally posted by From1980 While I find it amazing that this topic is being "discussed" AGAIN, the above post by newmikey should have wrapped it up. The need for UV filtration ended when film emulsions were generally being made without oversensitivity to the blue end of the spectrum a couple of generations ago and no digital camera needs help filtering for excess UV light. Even when I worked in a camera store 40 years ago the industry had become inclined to refer to the UV filters as protection for the lens. Then, as now, the potential degradation of the image far outweighs a claim to protection for the lens. Filters were sold at a very large markup compared to lenses and cameras so that two or three extra attachments or filters sold with a basic camera kit for $10-$15 each could often bring greater profit than a camera lens combined. Filters - 500+%, cameras and lenses - usually 5-10%. As mentioned previously here, equipment is less prone to damage with careful handling, extra glass surfaces can only degrade the image, and hoods and lens caps provide the best protection with hoods actually improving the results. Also, modern digital gear may suffer damage to electronic components in addition to optical issues when it's subject to "tossed in a bag" rough handling. It may be possible to work on better planning and technique for situations that can become very busy or hectic. A second body with another lens mounted may prove more useful than so much lens changing too.
Maybe it's just how I roll, I doubt I can change my habits. I shoot professionally, I wear a holdfast harness that has two cameras on my person at all time. I shoot a lot of primes and zooms and on my person are also lens pouch bags and other accessories such as flashes, light stands, softboxes... the list is endless.
I think a lot of these opinions are valid. I recall the glorious days of old when I didn't shoot professionally, went out for a walk with 1-2 lens and a tripod, oh the joy of freedom!! All I can tell you is that when working for money it becomes quite a different game entirely. I no longer have the luxury of time during a shoot like I used to. The level of multi tasking is on a whole other level. At first it was hoods to protect the lens, but then using filters for the times it was needed became annoying with so much screwing and unscrewing of items. Enters Xume Magnetic filter system which can be very useful and quick system to taking filters for a job off and on.
My OP was not about pros and cons of filter, simply what are the differences between Protective ones vs UV. It's everyone else that decided to go crazy and give their 2 cents on whether they had merit or not.
As I stated before, rear lens cap keep a place in the system I operate with because all rear lens caps are of the same size, one is on the bag somewhere, doesn't matter which one I grab because they all fit the any lens, the same can not be said for front lens caps. FWIW lens caps no longer work when the lens has a Xume Adapter also, so that's another issue and draw back of the system. Lens hoods if magnetised to the Xume Adapter also run the risk of being parted with the lens in the bag as it's jumbled around, screwing a hood on negates the purpose of Xume. Using Xume doesn't mean no using hood, it just means stowing the lens away with hood is not an option. But even if you could, that still doesn't stop the unthinkable happening such as a discarded battery making its way into the wrong compartment and making contact with the frome element with the hood on. I have found small stones in my lens pouches at times! Lord knows how they got in, bush walk, under a tree? I have no idea...
Right now I can look at my current lenses that have UV filters on them, they do indeed have small hairline scratches, I'd rather them have those scratches than the front element. I am a working professional but I prefer not to spend a 1/3rd of my payment from a job on a replacement FA77 when a $30 UV filter can give me some additional peace of mind. The idea that UV filters degrade IQ is just laughable to me. Yes there is some times a weird affect can occur, get familiar with when that might happen and then take it off, it's really no different than being aware of when a CPL might not work for even blue sky. It doesn't mean therefore all CPLs and wide angle lenses should never ever use them... I can show you my portfolio of FA43 and FA77 shots and you would never ever go "wow... they would be so much better without a UV filter"... plainly put no one would ever know if they had one on or off... so c'mon... let's get real here.
Anyway, I feel my question has been answered. Protective filters are just another money grab, go with a reputable UV filter if you have to (and I have to).
