Originally posted by BarryE I use B+W protective filters. Do they degrade the image? I haven't been able to conclusively say. When I started fitting them I tested in some very tricky lighting conditions and I could not perceive any differences. In fact in some flare conditions the end results might even have been aesthetically, slightly better. So I fitted them to all my quality lenses from new, reasoning that the benefits of protection, and probably resell, was worth it. I tried a Hoya filter and a Kenko and concluded I would not use these.
In some cases they imrove the weather resistance of a lens. I always use the added protection of a lens hood. Yes they are expensive, but I factor this in when I buy a new lens.
So I'm comfortable with fitting them and probably more relaxed about a lens' use, for instance when I forget to fit a lens cap and pop it back into my bag also with lenses that have short hoods, straps, branches, fingers etc would otherwise risk making the front elements.
The B+W filters are easy to clean I find.
I agree and do pretty well what you do. I generally use B+W F-Pro filters, generally clear filters to protect my lenses. I have tried a number of before and after tests...with/without filters...same subject, same weather/sun, etc. conditions and with the B+W have failed to notice any discernible difference.
In my many years of photography I have occasionally (very rare) dropped a camera. My K10D and 16-45 lens fell out of a poorly designed bag (dumped that one in a hurry) about 4 feet to the floor. I had a B+W on....the filter absorbed the impact as the camera hit the hardwood floor...lens first. Fortunately all was ok.
It maybe an unusual event , but even though I'm very careful with my equipment...sometimes (blank) happens, as they say.... not me though...I say (blank).
I do have some lenses that are impossible/ difficult to fit protective filters on...my 10-17 fisheye, my 40 and 70 Limiteds...so I go filterless.
I also believe that if you are going to put a protective filter on, use top quality filters. Why, put cheap glass on in front of expensive glass lenses ?
I also always attach my lens hood.
The discussion of the merits of filters is one of those perennial debates in the camera world . There will always be advocates pro and con. Who is right, I do not know.
