04-08-2020, 08:11 AM - 3 Likes   #1
External mobile power supply 8.3v
Corona time meaning time for projects that have been on hold for a long time....
I've found a battery pack (Trustfire Mobile Power Box) which holds 6x exchangeable 18650 cells. The output is exactly 8.36 volt. It also has a usb output.
(I connect a red usb light for night shooting)
I took the (Ex-pro) AC to DC converter with Pentax DC plug, cut the 8.3 volt lead in half, soldered female and male DC plugs on both ends.
This way I can use the lead on the AC adapter and on the battery pack to power my Pentax. (Couldn't find the Pentax DC plug in Europe).
I can also charge the battery pack with the same AC adapter
A lot of juice in those 18650 cells meaning long continuous shooting with my K3,KP or K1 !!
04-08-2020, 12:20 PM - 1 Like   #2
I fount the separate connector in an older topic on this forum.
https://uk.farnell.com/hrs-hirose/mq172-3sa-cv-50/plug-i-o-3way/dp/1518737
04-08-2020, 12:51 PM   #3
acoufap's Avatar
QuoteOriginally posted by Haenzel Quote
I took the (Expro) AC to DC converter, cut the 8.3 volt lead in half, soldered female and male DC plugs on both ends.
This way I can use the lead on the AC adapter and on the battery pack. (Couldn't find the Pentax DC plug in Europe).
I use this one ... Omni-20 - | Power bank with wireless charging and direct DC Input/Output plus Pentax camera compatible power supply. Maybe some day I'll tinker a cable with fitting plugs (if I can get them somewhere) that directly connects omni-20 via adjustable DC-Output with Pentax cameras.
04-08-2020, 01:14 PM   #4
QuoteOriginally posted by Sakura Quote
I noticed that page as well, however it says "no longer manufactured"
---------- Post added 04-08-20 at 01:31 PM ----------
QuoteOriginally posted by acoufap Quote
I made my post a bit clearer. The Expo AC adapter has got a Pentax DC plug. So I'm using that lead...The Powerbox comes at a price of only USD 12,=.
The Omni-20 is a really nice powerbank but for me a bit too pricy... (I'm dutch...)
04-09-2020, 12:11 PM - 1 Like   #5
But we have a part number: MQ172-3SA-CV(50)
And a short searching with google took me to Kynix
MQ172-3SA-CV(50) - Hirose Electric Co Ltd - Rectangular Connectors - Free Hanging, Panel Mount - Kynix Semiconductor
And at this moment they have 2437 pieces on stock
04-09-2020, 07:50 PM   #6
I know....I can Duckduckgo as well
I said I couldn't find it in Europe. There is a Corona crisis at the moment. How long will it take for this part to arrive in the Netherlands?
I just made use of an already available plug, however it was attached to the Ex-pro AC adapter...
04-11-2020, 12:23 AM   #7
angerdan's Avatar
Thats right, and if Haenzel would've searched the forum before creating another redundant thread, he could've find six already existing threads containing "MQ172-3SA-CV(50)":
External mobile power supply 8.3v - PentaxForums.com
External power - PentaxForums.com
Pentax AC Adaptor Kit K-AC50U - PentaxForums.com
D-AC50 power adapter cheap replacement - PentaxForums.com
Battery Life whilst using Remote Assist - PentaxForums.com
External power supply - PentaxForums.com
Pentax K-AC50 AC Adapter Kit help... - PentaxForums.com
Lantern battery for DC input - PentaxForums.com
Cold, cold batteries = headache (help?) - PentaxForums.com
External power source projects are also discussed here:
K-1 power supply for UK - PentaxForums.com
12 VDC power adapter for K-1 - PentaxForums.com
AC adapter D-AC 50 - PentaxForums.com
D AC76 adapter - PentaxForums.com
Can anyone recommend a source for a spare K-BC90 charger ? - PentaxForums.com
The MQ172-3SA-CV(30) is the successor of the MQ172-3SA-CV(50). So no big change here.
MQ172-3SA-CV(30) - HIROSE Electric Group [Connector]
And it is in stock inside europe:
[20pcs] mq172-3pa Stecker 3 Pin Monolithic SMD Hirose | eBay
04-12-2020, 01:49 AM   #8
QuoteOriginally posted by angerdan Quote
I initially replied to an already existing thread, however I was warned "this is a really old thread, do you really want to post here?"
So i decided to create a new one. Sorry if I messed up here...
The Ebay link you posted is a SMD chassis part. You've got male and female connectors.
I really regret having posted my solution. I apologize. Can the administrator please delete my thread?
Wish you all a great and peaceful Easter weekend!!
Best regards,
Haenzel
04-12-2020, 06:50 PM   #9
Great solution
I liked your solution Haenzel!
Using the plug from the AC to DC converter is really the least expensive and easiest solution. You get the AC power supply and the battery connection for the just a little more than the cost of the connection. I can find the connector for as little as $1.72 USD but the shipping is 10 which is really close to the cost of the AC power supply. Since the battery is already setup for the correct voltage for the Pentax K1 it makes for a great mobile solution.
04-13-2020, 11:36 AM   #10
Thanks
QuoteOriginally posted by photomission Quote
Thanks for your kind words!
09-13-2020, 01:55 AM   #11
angerdan's Avatar
Can you please post a picture of your setup and tell more about it?
PS: plug is available on ebay without power supply:
Hirose MQ172 Series Miniature Power Connector Cable mount plug, Lötzinn terminati | eBay
09-16-2020, 01:11 PM - 1 Like   #12
Take a look at the picture. Hope it will be more clear....
09-16-2020, 02:12 PM   #13
Otis Memorial Pentaxian
Thanks for this contribution. The beauty is the integration with the AC adapter as a charger while retaining it's value for direct power to the camera.
ac, adapter, battery, bit, cells, dc, lead, output, pack, pentax, post, power, time, tripod, usb
Replacement for 2CR5 dual 3V lithium battery Chuckie Pentax Film SLR Discussion 4 11-24-2019 06:24 AM
AC power supply 167 for k1 II or 132 version rechmbrs Pentax Camera and Field Accessories 13 05-19-2018 03:40 PM
3v CR1616 Battery on a Spotmatic F anselmopn Troubleshooting and Beginner Help 6 06-02-2017 09:51 AM
Pentax external power supply voltage tolerances beholder3 Pentax DSLR Discussion 9 02-16-2017 05:56 AM
External power supply mattv Pentax K-5 & K-5 II 12 12-22-2012 07:35 PM
All times are GMT -7. The time now is 08:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
