05-05-2020, 12:21 PM   #1
gump's Avatar
geared head
It appears a geared head would eliminate some minor frustrations with drifting of the ball head as I am locking down for the perfect shot. I am looking at the Manfrotto 410 as it is supposed to do the job and is well within the weight, need, and price parameters. Any insights, warnings, opinions, recipes?
05-05-2020, 12:53 PM   #2
QuoteOriginally posted by gump Quote
I had it and switched to the one I have now, a Benro. What I didn't like about the Manfrotto I had was the bulk, the weight, and, the big deal, the stupid Manfrotto plate. I'm an Arca Swiss kinda guy.
The Benro is smaller, lighter, and is Arca Swiss compatible. It has one quirk I don't like, and that is that the quick movement gear interferes with getting one of my cameras on and off easily---I have to turn the gear slightly for the body to clear. Another less problematic quirk is a bit of a hiccup when switching from the quick turn gear to the fine ones, but that one annoys me less.
I think there are another couple to consider---both more expensive, though. In retrospect maybe I should have gone for one of those since it's professional use for me.
But if you don't specifically need what a geared head delivers, then maybe just get a better ball head. I use Acratech's, and think they are very good. FWIW, I'm using them and my geared hed with a 645Z and a K1(upgraded).
05-05-2020, 12:58 PM   #3
Check this very recent video about geared heads.
05-05-2020, 12:59 PM - 1 Like   #4
PEG Moderator
Kerrowdown's Avatar
A lot depends on your style of photography or subject matter. Geared heads can become quite frustrating if you need to recompose promptly, as it can involve a lot of knob twiddling to get to the other side.
Perhaps even a more robust ball head might also be worth looking into. For example I'm using the RRS BH-55 and have never experienced any "drifting", even with larger heavy glass.
Really Right Stuff BH-55 Pro with B2 Pro II Clamp reviews - Pentax Camera Accessory Review Database
Hope this helps...
05-05-2020, 01:25 PM   #5
amateur dirt farmer
pepperberry farm's Avatar
I have a 410Jr head and love it..
05-05-2020, 01:39 PM - 1 Like   #6
baro-nite's Avatar
I own a Manfrotto 410. For me it has its uses, but also frustrations. Rotation along any axis also entails significant movement of the camera, hence change of viewpoint. That's because the optical center of camera/lens is well away from each of the three axes of rotation.
(I bought an Arca-Swiss conversion kit for the 410 from Hejnar Photo, who has an eBay shop.)
While I also own ball heads, currently my go-to rig is my own hacked-together version of a pan-tilt head: a leveling base, panning clamp, and monopod head. Because the monopod head itself has an Arca-Swiss base, I can quickly remove it when not needed (as when I put a view camera on it, or when doing stitched panoramas). For me this is easier and more versatile than a ball head, given that I nearly always want the camera to be level except for tilting up and down as needed.
YMMV
05-05-2020, 02:05 PM   #7
gofour3's Avatar
I use the Manfrotto 229 3D super pro head, works well for my type of shooting. (slow) I also like the long handles.
Manfrotto 229 3-Way, Pan-and-Tilt Head with 030-14 Quick 229 B&H
Phil.
05-05-2020, 02:25 PM   #8
I have the 410 with the Hejnar Extended Plate with F63 Clamp:
"Clamp center is located on Manfrotto 410 camera/lens mount axis and it is the same as the head panning base. When the head is panned both the head and camera/lens rotate around the same axis."
Extended Plate With F63 Clamp for 410 Gear Head
I mounted the 410 on a Platypod Max and used a K-1 with RRS L-bracket for the knick knacks up close contest picture.
05-05-2020, 03:28 PM   #9
I have a Benro three way geared head, love it. Arca-Swiss compatible , well built. I use it more than my ball heads and I have a RRS BH-55 ball head which does not sag even under heavy loads.
05-05-2020, 04:01 PM   #10
dms
I find ball heads to be terrible for careful work, as the minute you get one axis right, it changes when you loosen it for another axis. The geared head or a regular three axis head works better in this scenario. If you have not tried a regular 3 axis head, it may be the answer to what you need. Less expensive, lighter, and likely just as able. With a very heavy camera, and/or very fine contro,l I would see the advantage of the geared head, but not typically.
05-05-2020, 05:21 PM   #11
gump's Avatar
QuoteOriginally posted by gavinhw Quote
gavinhw
It was that video that spurred my renewed interest.
05-06-2020, 08:19 AM - 1 Like   #12
I've got the Benro GD3WH and it has changed my life for astrophotography. I have had the 300* or 16-85 mounted on the k3ii, and the gearing is a dramatic improvement coming from a trigger grip. Keeping a subject in the center of the frame is now a matter of a little turn of the gear. Much less guess and check for faint targets like Andromeda or Bode's. It really allows me to be more attentive to improving the other aspects of astro technique. Each gear has a 'full release' knob that allows you to slew it along that gear's axis quickly.
I have used both full sized ARCA plates and Peak Design's little square quick release on the mount. The release knob on the head is a little finicky, but not a deal breaker for me.
head, tripod
For Sale - Sold: Benro GD3WH 3-Way Geared Head Fenwoodian Sold Items 8 10-17-2019 08:59 PM
For Sale - Sold: Manfrotto MT057C3-G 057 Geared Carbon Fiber Tripod w/ Case loveisageless Sold Items 6 12-01-2018 10:41 AM
Manfrotto Junior Geared Head or better ball head? enoxatnep Pentax Camera and Field Accessories 9 05-04-2012 03:33 PM
For Sale - Sold: Manfrotto 3046 Studio Tripod with 410 Geared Head atupdate Sold Items 6 11-16-2009 05:54 PM
All times are GMT -7. The time now is 10:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
