05-07-2020, 05:14 AM   #1
Pentax-M SMC 50mm 1.4 - Lens hood
Hi guys,
A newbie here and I just want to ask if what will be the effect if I use this lens hood (28mm / 35mm) for a Pentax-M SMC 50mm 1.4? It fits on a 49mm filter thread and I don't want to buy it unless there will be any bad effects.
(Photo below is not mine. Its also here in Pentax Forums)
Thank you in advance!
Last edited by Emaaan; 05-07-2020 at 05:16 AM. Reason: Added that the photo is not mine
05-07-2020, 05:54 AM   #2
It will work but may not be as effective as a hood designed for the M 50. The hood serves a number of functions including lens protection, resistance to flare, and increasing contrast. This one is designed for wide angle lenses and is shorter than it would be if designed for the 50. The design is such that the hood will have some tolerance to avoid vignetting at the corners. I personally prefer the collapsing rubber hoods although they are also not optimized for the focal length in the way that modern tulip shaped hoods are designed.
05-07-2020, 07:17 AM   #3
ramseybuckeye's Avatar
As stated above, it won’t be optimal, but if you ever get a 35 or 28 you’re set, I believe that wil work well on the DA 35/2.4 also.
05-07-2020, 07:24 AM   #4
pschlute's Avatar
Something like this would offer better coverage for the 50mm lens........ JJC replacement Pentax PH-SA49 lens hood. Compatible: Amazon.co.uk: Electronics or the rubber hoods advised above work just as well.
05-07-2020, 09:26 AM   #5
Wasp's Avatar
It won't help much on a 50mm, more so if you use a crop frame camera. In that case, you apply the 1.5 crop factor and get one marked 75mm, or 85mm would be the closest you can get.
It is however a cool thing to have, especially if own one of the lenses marked on it. Or plan to own one. Get the hood, get the lens. That's how it works.
50mm, 50mm 1.4 lens, hood, lens, lens hood, pentax smc 50mm, pentax-m, pentax-m smc 50mm, smc, tripod
Lens hood info for SMC Pentax K-50mm F1.4 abw Pentax SLR Lens Discussion 15 10-25-2018 06:19 PM
For Sale - Sold: SMC Pentax-A Macro 50mm f2.8 lens $99 shipped Plus FREE SMC "A" 50mm 1.7 lens Ronald Oakes Sold Items 4 06-12-2018 05:51 PM
SMC DA 50mm lens - lens hood? bobbotron Pentax DSLR Discussion 4 02-07-2015 09:21 PM
For Sale - Sold: SMC 85mm f/2.2 Soft, SMC-M 50mm f/4 Macro, SMC-M 135 3.5, SMC-M 85mm 2, SMC-M jgmankos Sold Items 3 06-14-2010 06:48 PM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 07:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
