Originally posted by luftfluss What shutter speed are you hoping to achieve with the tripod? I have an Oben carbon fiber tripod that for my use works very nicely with the K500, but I am nearly always shooting at least 1/250s, and usually faster.
I try to keep shutter speeds about where you're keeping yours, or higher. I tend to use the K500 at higher ISO and 1/500 or better. Thanks for the lead on the Oben, however carbon fiber sounds expensive. This tripod will pretty much get used only for this lens (and the A*600 if I stick with Pentax and actually get one), so I don't want to overspend. Thanks!
Originally posted by david94903 I do a lot of tripod work "in studio" (that's code for the dining room) so I don't mind the weight issue of the larger tripod and the heavier ball head (I was a bit stunned a how large the BH-55 actually was when I got it). And when I do take them out, I'm willing to haul them because I know I won't have to fuss with them.
Thanks for your specific suggestions... I'll do some research. "In studio" is how I intended to use this tripod (aka, around the house). I don't intend to take it traveling very far, maybe around the county as we explore, but certainly not going hiking with it. I have a nice but too expensive Peak Design tripod that works fabulously for my K-1mII units and every other lens I have, but it's not up to task for the K500 despite being labeled for 20 pounds.
Originally posted by kypfer Choice of head may be down to style of photography.
True. I've only ever used ballheads, and never even touched a gimbal. I'm not averse to a gimbal, but just have no experience and therefore no expectation.
Originally posted by Lowell Goudge There are really two things to consider the first is a tripod, but the second is the mount. I have a Tamron 200-500/5.6 and I put a jobo Jr gimbal head on my tripod, got the right extension plate and was frustrated with the vibration. So I took the j shaped swinging ark of the head, and mount the lens to the pivot directly. What a difference in vibration. The lens is now rock solid on the head, it is still balanced around the pivot, so I use it that way
Sounds like you found the weak spot on your setup. Are you able to swivel the lens up/down while mounted like that? Thanks for your input!
Originally posted by Oldbayrunner Originally posted by jlstrawman Manfrotto 3011BN tripod with 3130 Fluid head. Heavy and sturdy. Used for nearly 20 years with no problems.
Thanks for the leads, guys!
Originally posted by aslyfox have you looked at the user reviews of such gear here yet:
Of course I have, and thanks for the link. Posting direct questions always generates some good back/forth discussion about specific concerns, even when the question is stupid or inane as this one is. That's the beauty of this forum... 99% or higher hit rate for positive discussion, and by far best I've experienced on the internet. Secondly, I didn't have to waste my time reading thru a bunch of reviews irrelevant for this purpose. Plus the tripod catalog there isn't exactly complete. Thanks, and stay safe.
---------- Post added 26th May 2020 at 09:40 AM ----------
Originally posted by marcusBMG Of course if you're eg tracking birds then you can't hands off and let the tripod + lens settle to a motionless state (which is the ideal). I guess the way I try to operate is similar to most - left hand on top the lens acting a bit as a damper, right hand operates the camera. It's clear that there is every possibility for shutter press jerk, no matter how hard one tries and practices. My own thought is that I should still be trying to use a remote shutter release as often as possible.
Just my thoughts.. I'd be interested to hear how others work.
Thanks for this. I was not doing anything like this. For subjects that allow it, I use 12s delay, but no remote release. Also, I've noticed EFCS makes a significant difference in sharpness.
Originally posted by bdery There are so many tripods to choose from. Anyone will have experience with a few units at best. So it's hard to make definitive recommendations, other than "I like what I have" (or don't like).
That's kind of what I was looking for. Thanks!
Originally posted by Kerrowdown Remember it's not just legs, but also a good head will be required too.
Are you still talking about tripods? ;-)
