Originally posted by jbrowning So I'm looking for filters for my Bigma that I have been using quite a bit. I already have a UV and Circular Polarizer. This lens takes a 86mm filter.
I have the Cheapma and I am able to use a 86 to 77mm step down ring on it. This makes filters a bit less expensive and the Corkin P series will now work with the lens.
I'm not sure about the short end on the Bigma, but you might see how small you can go. I only needed 77mm, that is the filter size I owned, so didn't see if a smaller step down ring would work.
