07-29-2020, 09:14 AM   #1
Help Asahi-Pentax Adapter K for 6x7 Lens
Dear pentax-forumers,
I've just acquired an original Asahi-Pentax Adapter K for 6x7 LENS in mint conditions, here in Italy by a gentle vendor of Milan.
Before to mount 67 lens i've downloaded at manualslib.com, the manual that at page 4 says:
"...To detach the lens, push the un-lock button (5) and turn the lens counterclockwise."
But the black&white scanned images are poorly, i don't understand where is this un-lock button...
Please give me a solution, thanks ...
I suspect is this (?) :
[There aren't others buttons apart the large knurled knob for friction, on the barrel, the rotation of the lens attached.]
But, in the case, without mounting the 67lens, this aluminum button is completely RIGID, BLOCKED ... it is normal? Shall i lubricate it ?
In the doubt I'm afraid of mounting my P67-55mmf4 on the adapter; after that i'm afraid not detaching more from it ...
Thanks to anyone gives me infos ...
Best regards
Ben
07-29-2020, 10:35 AM   #2
Yes, that is the correct button to un-lock lens. You should be able to push it down even without lens attached. If you look at the inside of the adapter, when you push the button, there's a lever moves slightly. If the button is stiff, try to check if there's any gunk that binds that lever.
07-29-2020, 12:18 PM   #3
Hi hyyz, thanks...,
"...You should be able to push it down even without lens attached."
Yes, that lever moves slightly if i touch it ... but the push button is stiff ... all seems clean ..
07-29-2020, 12:35 PM   #4
I compared yours with mine. As long as the lever moves, yours is working fine. The button feels some resistance when pushed. That's normal.
07-29-2020, 12:41 PM   #5
The push button seems welded, completely blocked... a little drop of WD40?
...the distance is about one millimeter...
Well now, thanks to hyyz , i know that I should be able to push it down even without lens attached.
07-29-2020, 01:00 PM   #6
That I don't know. You need to make the lever move by pressing the button - this is how lock/unlock work. If it doesn't work, you could try lubricant.
07-29-2020, 01:04 PM   #7
Thanks very much, hyyz.
All the best,
Ben
07-29-2020, 02:21 PM   #8
... damn(!), i can't resolve...
The push-button is welded ... seems to have, internal/external, a different cross section dimension ... internal is bigger and concentric ...solidified grease? rusty?... alcohol denat drops failed...
Uhm... tomorrow is another day!
Good night from Italy,
Ben
Anyone knows where can i find a "decent" manual use of this piece ?
---------- Post added 07-29-20 at 02:41 PM ----------
A bit better than manualibs:
https://www.cameramanuals.org/pentax_pdf/pentax_6x7_lens_adaptor.pdf
07-29-2020, 03:13 PM   #9
Sorry to hear. Judging from your pictures, yours looks exactly the same as mine. The button has a pin inserting into the hole on the adapter. The other end of the pin (inside the adapter) is larger than the pin itself. I guess this is to prevent the button from falling out. The pin directly pushes against the lever. I don't see any other mechanism. On my adapter, if I move the lever from inside, the button/pin can slide easily through the hole. I think your adapter may have rust at the pin-hole connection. Good luck!
07-30-2020, 06:53 AM - 1 Like   #10
SOLVED !!!
The lubricant, this night, has done his work.
Now the push button is free (!!!), i've dropped it, at the first, with alcohol denat with a dental floss, then with abundant and directly sprayed Arexon lubricant "Svitol" leaving it, for twelve ours, in vertical position second the axis of pin-hole and laid on a folded sheet of absorbent paper.
On the paper today some yellowish traces ... probably dirty solidified grease, now the push button is free, fluent; i can even rotate it, and present a very light resistance to the pressure and operates a fluent action of the lever inside the adapter.
Luckely no rust (!) ... it's amazing how few invisible dirt blocked the push button axis, ... such as welded !
Thanks also to the valuable assistance of Giorgio Melgrati.
Thanks again very much to the valuable suggestions of "hyyz"!
Best regards from Italy,
Ben
07-30-2020, 07:05 AM   #11
Great news! Glad you make it work. Now, you can put it in use.
adapter, asahi-pentax adapter, lens, tripod
For Sale - Sold: Pentax 6x7 300mm F4.0 and Pentax 6x7 200mm F4.0 MightyMike Sold Items 60 12-27-2020 03:10 PM
How I got B. Kronberger's Asahi Pentax Spotmatic II w/ 50mm f/1.4 Asahi lens Judy Darby Welcomes and Introductions 5 10-24-2018 04:47 AM
For Sale - Sold: (New price)Asahi Pentax AP and Asahi Pentax K cameras 1957-58 (+ Pentax H3 and H1a ) 17dew Sold Items 13 10-08-2018 10:53 AM
For Sale - Sold: Pentax 6x7 400mm f4 SMC Takumar & 6x7 to K mount adapter littledrawe Sold Items 8 04-30-2012 04:58 PM
All times are GMT -7. The time now is 03:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
