I got inside the Spotmeter. The two LEDs for 1/3 EV increments are behind a small piece of transparent red plastic. This had become cloudy and was blurring them. IDK why the red plastic was there as the LEDs are red anyway; it was only glued in place and I removed it. As well as being more focussed now, the LEDs look slightly brighter, in fact a bit more than the numerals, so I guess its purpose was to match the brightnesses. The meter is as good as new now
There was indeed a screw under the serial number sticker (1st pic). This, and the big chrome ring nut at the viewfinder position (2nd pic), and a small plastic tongue at the top, are what hold the case back to the front. I had to make a pin spanner to undo the chrome ring - a bit of metalwork.
Once the case was apart I had to remove the case front from the main internal "block" of pentaprisms and stuff. First the long circuit board down the handle and the operating microswitch were removed (within the limits of the wiring). Then I took out the object lens to reveal four screws behind it to remove the lens barrel. This revealed a large brass ring nut (3rd pic) that I undid with waterpump pliers. After that the internal "block" could be removed from the case front. The small circuit board carrying the LEDs and numerical display was attached to the front of the "block".
