12-23-2020, 12:04 PM   #1
jpzk's Avatar
S-Type screen from Focusing Screen -- confusion -- help needed.
Hello all.
I have this focusing screen, S-Type, which was meant to be installed on a K7. (from Focusing Screen.com)
It is still "brand new"/unopened and I need to know:
Will it fit a K5, K5II, K5IIs as well?
Hard to find a proper place to find this here in spite of many threads and posts relating to that.
Thanks in advance, folks!
12-23-2020, 12:25 PM   #2
Otis Memorial Pentaxian
Yes...it will fit all flagship APS-C from the K-7 forward and consumer models from the K-30 forward.
12-23-2020, 01:13 PM   #3
cpk
cpk's Avatar
When I converted my K-7 to infrared, I moved my KatzEye focussing screen over to my K-5 II. Unfortunately they closed down before I had a chance to send that camera to them for calibration.
12-23-2020, 01:18 PM   #4
QuoteOriginally posted by cpk Quote
You can probably move the shims from the K-7 directly over to the K-5II, assuming you still have the shims.
12-23-2020, 01:22 PM   #5
jpzk's Avatar
Thanks a bunch to all of you !
Much appreciated!
12-23-2020, 01:42 PM   #6
Thanks to all for the replies! I was needing this info too. Much appreciated.
12-23-2020, 07:14 PM   #7
cpk
cpk's Avatar
Thanks, Steve, for the suggestion. The focus now on the K-5 II is close but not perfect with the KatzEye split image focussing screen. Indoors with the K-5 II I tend to use the autofocus; and outdoors, with the smaller apertures and more depth of field, it may not matter much. I have never changed the shims, only the screens, on my cameras; and that makes me nervous enough as it is of causing damage through a misstep. But I will give your suggestion some thought.
Added: All my focussing now on the K-7 is done in live view, so the calibration of its focussing screen is unimportant.
12-23-2020, 07:44 PM   #8
jpzk's Avatar
If you are getting good results with the K7, using the live view method, why not do the same with the K5 II ?
12-23-2020, 07:56 PM   #9
cpk
cpk's Avatar
QuoteOriginally posted by jpzk Quote
Because it requires this type of attachment to enable easy use of the camera outdoors in bright light:
Hoodman Live View Kit for all DSLR Cameras - HLVKIT
That's an added cost, extra bulk, and no advantage to it over the optical viewfinder. Also slower to use. It's good for infrared because the focus points of a lens differ from visual light.
12-23-2020, 09:05 PM   #10
Yes it will fit.
s-type, s-type screen, screen, tripod
For Sale - Sold: Pentax K7 ; LCD monitor cover ("window"). jpzk Sold Items 16 02-24-2021 07:43 PM
Favorite focusing screen type? abruzzi Pentax Film SLR Discussion 11 02-24-2019 10:09 PM
Diopter Confusion Re the K5- Help Needed markpsf Pentax K-5 & K-5 II 3 05-20-2011 08:22 PM
Focusing screen help needed! Itsbudda Pentax Film SLR Discussion 16 09-21-2010 09:19 PM
Focusing manual lens with OEM focusing screen, is a split screen really needed? skid2964 Pentax Camera and Field Accessories 16 09-17-2010 02:54 PM
All times are GMT -7. The time now is 01:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
