Originally posted by 87Duckfan Oh, I'm also looking at a Slik Able 300 DX for $40. Anyone ever owned one of these? Good or bad feedback?
I have the Slik 700 Pro DX legs (with Manfrotto head, so can't speak to the Slik heads) and it does the job well. My version is a rather tall and metallic alloy giving it a fair bit of weight that would make it less suited for hiking. I personally like that aspect because I do a lot of long exposure work, and the weight keeps it solid without needing to add a weight bag or anything to it.
The center post is sturdy even at full extension due to a double lock. There's a twist locking collar at the top, and a second tightening knob on the side. I will say if you don't lock both down, there may be a risk of it sliding down unexpectedly with your camera on it. On the other hand, doing that will also leave the post a little unstable. If it's wobbly, then it'll clue you in that one is them isn't fully tightened.
The leg angle limiters seem a little on the weak side from a design standpoint because they don't lock anything in place, and are themselves not able to be fully secured from accidental movement. They pull out to adjust for a wider stance, and there isn't a way to lock them in place. In practice, this hasn't been a big issue. I just have to make sure the legs themselves are up against the angle adjustment limiters during setup. They failsafe to a narrower angle, so once set up, everything does remain in place with no issues
I've had it about 6 months with light use, and no problems so far. I don't know how accurate the load capacity rating is, though. Mine is rated at 15 lbs, but I don't come anywhere near that with my gear.
