01-10-2021, 11:11 AM   #16
Another vote for OpTech.
Well made and resonably priced. I didn't think I would care for a cross strap until i used one. I use a cross strap (with quick release attach points) that can be converted to a neck strap. I attach it at the upper RH mount and lower mount plate on my KP and that lets my FA* 300 hang straight down to my right when hiking/walking. I have a third quick release on a carabiner that I attach to my front beltloop and to the LH mount if the camera is bouncing around too much while walking.
If I am using my primes or I am not going for a long walk, I use the wrist strap.
01-10-2021, 02:23 PM - 1 Like   #17
jddwoods's Avatar
Domke Gripper...same material and design as the straps on their bags.
Domke 1.5" Web Camera Strap with Swivel Quick 742-1BK
I bought two of them. One is the 1.0 inch with swivels and the other is the 1.5 inch version with swivels. Once you attach the parts with the swivels on the camera you can instantly swap the wider strap (for heaver lenses) with the narrower lighter strap when lightweight with smaller lenses such as the limiteds is desired.
01-11-2021, 04:10 AM   #18
I'm personally partial to a belt system; using a sling while hiking I've always ended up with a stiff neck and it's a hassle to wear it under a backpack.
I don't have lenses that are *that* heavy, so I can't personally vouch for weight over 4-4.5lbs, but at those loads a 20km hike with this (CP Tech B-Grip Evo Belt Grip For Cameras: Amazon.de: Camera & Photo) is not an issue.
01-14-2021, 08:05 AM   #19
Lots of good comments
01-14-2021, 01:25 PM   #20
bdery's Avatar
Op/Tech is fine, but several years ago I switched to Peak design, and couldn't be happier:
Peak Design Slide Strap and Capture Clip System Review - Introduction | PentaxForums.com Reviews
01-14-2021, 05:43 PM   #21
Lowell Goudge's Avatar
QuoteOriginally posted by Smoke665 Quote
Need recommendations on a heavy strap/sling capable of handling up to 10lbs. Not a big fan of the cross body/should sling, but that may be my only option.
What are you carrying, I use optech on the DA560 +K1. Combined it is about 5 kilos 11 pounds for the metric impaired. I adjust the length to be cross body I.e. ove neck and shoulder, with the lens at my hip.
QuoteOriginally posted by jpzk Quote
Optech/USA ... I have three of them, especially one for my K3 + Da*300/4 + grip .
Tough, reliable.
I also have the "harness" (also from Optech/USA). That one sure would fit the bill!!
OP/TECH USA | Comfortable neoprene camera straps and slings | OP/TECH USA
Find a Strap | OP/TECH USA
QuoteOriginally posted by aslyfox Quote
I too have chosen the Optech USA strap system - utility strap
I also use the Joby UltraFit Hand Strap with UltraPlate with the strap
I can place my hand into the grip to control any swing of the camera equipment and help with the weight
I also vary how I carry the camera and lens, cross body, or held in the crook of my off elbow or balanced carefully on my shoulder
QuoteOriginally posted by hcc Quote
+1 for the Optech (USA)
I regularly use this one with my K=3 and all my lenses, incl. FA*300 f4 and the heavier (infamous) VL125mm f1:
OP/TECH Pro Loop Strap reviews - Pentax Camera Accessory Review Database
I have used mine for more than 4.5 years without a single issue. I found this one very confortable and suit my needs.
I hope that the advice may help.
QuoteOriginally posted by pentageek Quote
Optech or Peak Design. Quality is similar, Optech seems to be more versatile system in terms of various scenarios it can be used in. Peak Design also builds its system, but they are slightly behind Optech. I use both systems, Peak Design for 'generic' K-1 configuration, and Optech for Mamiya RB and K-1 with Sigma 150-500.
Optech, Black Rapid, Peak Design ... all great gear.
QuoteOriginally posted by 7.62lew Quote
To all the optech users, after 30 years myself, all I can say is I agree with you
01-15-2021, 07:04 AM   #22
bdery's Avatar
Seems like I'm not alone in this
OpTech straps, with their stretchy neoprene, are very comfortable. The sliding element on their sling strap is nice. The buckles are simply too large, and it's not versatile in the places you can attach the clips.
01-15-2021, 10:45 AM   #23
The only issue I see, is that the attachment clips are designed to only attach to intended manufacturers strap loops. I have the attachments on all my bodies, (5 DSLRs, 3 film bodies) plus the DA560, and my binoculars it is useful to be able to only have 3 straps. I also use the same system to tether my GPS to my backpack.
I donít really have an issue with the 3/4 inch clip size and quite honestly would be worried if it were smaller. They test all clips to something like 140 pounds if I recall correctly.
01-15-2021, 12:17 PM   #24
bdery's Avatar
I do the same with Peak Design clips. And I was even able to create my own hand strap with that system, which led me to use a strap less and less.
I don’t really have an issue with the 3/4 inch clip size and quite honestly would be worried if it were smaller. They test all clips to something like 140 pounds if I recall correctly.
Size isn't always the best indication. for instance, I do trust Op/Tech's clips, but I also trust the Peak Design clips, which are much smaller but were tested to 200 pounds each.
01-28-2021, 03:39 PM - 1 Like   #25
MarkJerling's Avatar
Have a look too at this recent discussion: Using heavy lenses with straps - Page 2 - PentaxForums.com
01-30-2021, 07:12 AM   #26
Thanks for all the advise. Finally went with a BlackRapid Curve Breathe. Found a new "open box" that was substantially cheaper than anuthing else I looked at. Initial impression is that it will do the job, but until I have a chance to actually use it, I won't know if I got a bargain.
tripod
Heavy Duty Tripod jcrutchley Pentax Camera and Field Accessories 16 01-04-2020 09:39 AM
Best (current) heavy duty tripod models for a Pentax 67? vZwicky Pentax Medium Format 27 02-11-2015 09:27 AM
Jury Duty- would you do your duty ? lesmore49 General Talk 58 01-20-2010 02:33 PM
Looking for Heavy Duty Tripod Suggestions dadipentak Pentax Camera and Field Accessories 61 02-19-2009 09:17 PM
All times are GMT -7. The time now is 01:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
