Originally posted by magnum1 Really? I was under the impression that once they are warmed up they run at their listed 5600k.
If you look at a spectral analysis, you will find that while they emulate 5600K, they have spikes and drop outs in their spectral output.
This, in itself, probably isn't a big deal, although some colours may reproduce badly because of it.
My real problem is what I got in the samples above. Those pictures were shot sequentially on continuous advance, so should be taken within 1/3 second of each other, but the white balance is completely different, and I was unable to bring them to identical during raw conversion.
The reason, from what I've been able to ascertain, is that the light wasn't the same colour from one picture to the next.
This may prove to not be a problem for you, but it does make me suspcious fo using florescent lamps as a light source.
Out of curiosity, have you checked into some of the lower cost monolights? I don't know how their pricing compares to what you are looking at, but I think strobes is the better way to go for studio lighting.
In my sample pictures, the room is lit by banks of 8' tubes, and had been on for over an hour when those pictures were taken. They are part of a series of six images of the dog doing a recall. Three pictures show a fairly normal colour, thee pictures do not, and are all different.
If you want, the series is posted here:
http://users.accesscomm.ca/wrobb/temp/whitebalance/wb.html
The images were shot on auto WB, but I have been assured by several sources that the failure is the lights, not the camera
