Originally posted by Ishpuini I have two Filter Nest Mini from Mindshift.
Filter Nest Mini - camera lens filter pouch wallet case ? Think Tank Photo
Each has 4 colour coded pockets, one being a bit wider. I had a few other cheaper solutions earlier, but these were either not very practical or didn't survive my abuse. So I decided to spend a bit more and have been happy to have done so since. They are perfect for my 77mm filters and step down rings.
I love Mindshift. Their Nest Mini looks great, but a bit large for what I need. For the moment I use something like this:
https://www.amazon.ca/-/fr/DomeStar-dappareil-transport-professionnel-R%C3%A...6175470&sr=8-6 Originally posted by ramseybuckeye I can keep three or four filters in a pocket in the back of the bag
You just throw the filters in that pocket without protection or anything to sort them?
Originally posted by tuco Lens Stack Caps work well. You screw all your filters together and cap the stack of filters off on each end with a metal screw-on cap.
That's ideal for compactness, but not ideal for protection or for quick access.
To give a bit more context: I mainly use three 67mm filters and a very nice Revoring filter holder from H&Y:
REVORING Variable Step Adapter To Fit Screw-In Filters | H&Y Filters
That adapter means the 67mm filters can be used antively on my 60-250, on some lenses I have on other systems and, thanks to the Revoring, on all my other Pentax lenses (diameters between 49mm and 62mm).
I plan on getting a magnetic filter mount on the Revoring and on my 67mm lenses, and either get a 67mm magnetic polarizer or a converter for the regular one I have, and converters for my ND filters. That would really speed up mounting, but does nothing for quick access.
The Revoring has its own neoprene sleeve, but it has no attachment points If I use a magnetic mount, there won't be any need to protect the Revoring since it's not fragile (when a filter is mounted, of course it needs protection).
Using an all-magnetic system, including the caps for filter protection, would allow the use of a system like the one proposed by @tuco, but it would make the system very expensive and very thick.
For the record, the magnetic system I'm looking at is the upcoming Kenko Pro1D+ Instant Access. More versatile and less expensive than Freewell (and for filters, Kenko = Hoya).
Note that I also have a 67-82mm Revoring with built-in variable ND filter, but this one is hug and not often used.
