For my older tripods with centre columns , I used a sunnawayfoto 90mm leveling base. It worked "ok" sure, it did it's job, but, was a little fiddly to use. It screwed directly to the top of the tripod, the ballhead, or gimbal ect would then attach to it. As I said, I found it fiddly to set, the locking was via a screw on the side of the base, it was ok, but, I found it did introduce another amount of flex and vibration into the whole setup. Setting my level point I found a little bit of back and forth tilting was needed to bump it into position, and sometimes when I locked it up, I found it was slightly off where I had set it.
With my gitzo series 5, I went the bowl attachment style leveling base. it's actually a 75mm bowl, and the leveling base. and it is excellent. As you say , no centre column, but not really an issue for me, and if I am shooting with my gimbal, ( camera mounted on the gimbal with a nodal rail) I actually have used the side on the gimbal as a slight riser when doing some studio shots, it gives about 2- 2.5 inches of rise, which may not sound like much, but is very handy when framing products ect. The leveling base is solid as a rock, super easy to lock and unlock, with the screw lock underneath, and super easy to set level, or at whatever angle I need.
Feisol, induro, benro, leofoto ect ect all have the same basic design for these, bowl attachment style bases, the size of the bowl, depends on which series tripod you have.
