04-19-2021, 03:02 AM   #1
LittleSkink's Avatar
Gritty ball head
as it says really, I have an older ball head that isnt nice to use any more - its got gritty on pan, the ball is still smooth
is that fixable or once these things get wear / damage inside they are toast?
04-19-2021, 03:47 AM   #2
QuoteOriginally posted by LittleSkink Quote
If the design allows you, just take it apart and have a look. Both surfaces should be smooth. If they're not use some whet based sanding paper (gritt 800 or higher) on a glass plate and smoothen it by circulair movements. After done put a very thin layer of high temperature resistent grease on the surfaces and put it back together....
04-19-2021, 05:53 AM   #3
bdery's Avatar
Indeed, maybe simply disassemble it? Take pictures at each step, label screws, etc, and you should be able to put things back in place.
04-19-2021, 06:13 AM   #4
c.a.m's Avatar
Ball heads are relatively simple devices and, generally, they can be disassembled easily. You could look for examples on YouTube.
A gentle solvent such as mineral spirits can be used to flush the grit and other gunk. Mating rotational surfaces should be coated thinly with grease upon reassembly. Note that the spherical head should not be greased.
- Craig
04-19-2021, 06:38 AM   #5
Kozlok's Avatar
Generally, either you have wear particles in the pan mechanism, or some kind of contaminant. If it's contaminant, cleaning out and lubricating should fix the problem. If it's wear particles, the same process may or may not fix it. If you are not inclined to disassemble it, I'd blast it with WD40 a couple of times, and see if that fixes it. It often does.
04-19-2021, 08:22 AM   #6
Not a Number's Avatar
Use a nice damping grease for a smooth pan.
ball, head, tripod
Gritty results-K1mk2 pictures with 560mm Tim_RichertImages Pentax Full Frame 34 05-19-2021 11:21 AM
Beike ball head tripod head. Dewman Pentax Camera and Field Accessories 16 05-23-2015 07:07 AM
Tripod Head - Can I add Rotation to my current ball head claimed4all Pentax Camera and Field Accessories 5 10-11-2011 09:34 AM
pan-tilt head vs ball head raider Pentax Camera and Field Accessories 9 11-02-2008 09:13 PM
For Sale - Sold: Manfrotto 190 xproB; Ball head 486rc2 and ball head 808rc4 Not Registered Sold Items 6 05-31-2008 06:06 AM
All times are GMT -7. The time now is 10:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
