Originally posted by mikesbike I wouldn't wait too long, as "on back order" could mean it winds up discontinued. One reason being, I've noticed lately, more cases are for mirrorless, and not as many for DSLR use. And those for mirrorless often not only being inadequate for DSLR use, but also not having desirable features, like front accessory compartments, or belt loops in addition to shoulder straps.
Another thing, some of those cases are (for my use) too large, which is why I have more than one, depending on the lens sizes I will by using. To accommodate any of the various versions of the DA 55-300mm lenses, though not a small size- would require only a moderate sized case, with the main consideration here being a front/back depth that will accommodate the battery grip. Not sure about your M 35-105 FF zoom lens for depth. Good luck, and it seems you are on the right track.
Thanks. Got a notice from B&H a couple days ago that it has shipped, should be here Tuesday. I'll report back.
