Originally posted by ProfessorBuzz Sorry... forgive me ... I'm a bit grumpy this morning.
I probably should have asked what you had in mind for it?
For me, I do a lot of product shots, and having an external monitor helps with details. The challenge with small displays is that the pixels aren't large enough to tell if you have an issue.
No problem, my answer wasn't sarcastic, really appreciate your opinion.
One thought was that a DSLR basically also offers most possibilities of a mirrorless, in LV. And for second, I stumbled upon that item without having been searching for an actual solution for a real problem.
I'm into cultural heritage documentation and often use my camera away from the eye, on tripods pointing straigt up, on poles or even kites. For most things the KP does it quite well, for the kite a GRII is the perfect tool.
However, the K-3III has some advantages and I was curious if the fixed screen (unfortunately for me this would be a drawback) could be overcome by such an HDMI EV. Even if it is an external device the whole package could still be held fairly compact. A larger monitor has it's value, but I would miss the handheldability.
Though, thanks for all your opinions.
