Of course, buying a complete set is the hassle free approach. I have to say, I love the look of the complete set.
A few practical hints from a long time owner:
- Using the bellows/slide copier combo with APS-C is nearly impossible. I couldn't find any lens that allowed me a full coverage of the slide frame within the limits of the copier and the bellows.
- With the K1 theoretically it is easy - everthing (almost) as it was in analog times.
BUT: The K1 collides with the rear part of the bellows A (see again
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.). In order to circumvent this, you need a small extension tube. I use the smallest one from the Auto extension tube set K.
If you purchase another bellows, you might also encounter issues with the protuding part of the pentaprism.
Last but not least: If you want to use this combo for digitizing slides, you need a lot of time.... I prefer using a dedicated slidescanner which gives you the benefit of automatic dust removal. Only for the very few underexposed or otherwise problematic slides I set up the K1 with the bellows.
