06-27-2021, 08:25 PM   #31
QuoteOriginally posted by csa Quote
Yes, I'm thinking that's the only alternative I have.
You might try a longer bolt of the proper diameter and thread pitch.
06-27-2021, 08:25 PM   #32
csa
csa's Avatar
QuoteOriginally posted by DonV Quote
A larger diameter ring is what is needed, or remove the cover under the ring area.
As another member suggested, I'm simply going to cut off a strip of the cover, the width of the ring. I will have that extra strip that will still be in a circle to use, if I need it elsewhere.
06-28-2021, 06:26 AM - 1 Like   #33
UncleVanya's Avatar
The eBay link that isn’t working for you showed a Canon lens someone where someone had done basically that, then they also cut the ring and glued it to the tripod collar. The cut part could be lined up with the opening on the collar. I’m not sure would be smart to do that just pointing out another possible approach.
06-28-2021, 07:22 AM   #34
csa
csa's Avatar
Thank you! I could always use the double-stick tape, rather than glue, if I decide to cover the tripod ring. That way, it's not permanent.
06-28-2021, 07:27 AM - 1 Like   #35
UncleVanya's Avatar
Glad to help.
06-28-2021, 01:24 PM   #36
That's very strange -- I wouldn't want the tripod collar going around the lens coat even if it could be fastened. That would undoubtedly lead to slop/play during tripod or gimbal use.
07-30-2021, 02:01 AM   #37
Are you using a custom tripod foot? I have a similar Lenscoat for my DFA150-450 and that leaves the tripod foot free. I would cut away to allow it to attach in your case. You could always use the excess cut off material to glue it onto the foot if you want it covered as well.
cover, foot, hole, integrity, lens, lenscoat, lenscoat lens, link, location, post, size, tripod
LensCoat is looking for a Pentax-FA* 250-600mm F5.6 to make a cover for LensCoat Pentax SLR Lens Discussion 5 11-02-2021 03:45 PM
LensCoat lens cover csa Pentax Camera and Field Accessories 4 02-23-2019 06:47 PM
home made DA 560 lenscoat Glorfindelrb Pentax SLR Lens Discussion 4 09-09-2015 02:57 AM
LensCoat Lens cover agrzesiak Pentax Camera and Field Accessories 3 06-09-2014 01:35 PM
All times are GMT -7. The time now is 10:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
