For those that own the KP and K-70, finding a 3rd party remote shutter release is a little more difficult since Pentax changed the plug format for these cameras. Earlier Pentax DSLRs use a 3 conductor 2.5mm TRS (tip/ring/sleeve) plug. The KP and K-70 use a 4 conductor 3.25mm TRRS (tip/ring/ring/sleeve) plug.
I discovered this the hard way when I ordered the Pixel RC-201 E3 shutter release cable, thinking it would work with my K-70. Being an electrical engineer and tinkerer, I decided to physically replace the cable/connector on the Pixel remote with a cable that has the proper size and configuration connector. I purchased an inexpensive pre-made cable from Amazon that has the proper connector on one end and bare leads on the other.
After some careful experimentation I was able to determine that the sleeve is ground (or Common), the first ring closest to the sleeve also needs to be connected to Common, the second ring is connected to the focus contact and the tip is connected to the shutter release contact. Putting it all together this works exactly the way it is supposed to and looks like the remote was manufactured this way to begin with.
But for those that aren't tinkerers, this can be accomplished by using a simple 2.5mm female to 3.5mm male adapter like the one shown below. I hope this is helpful to someone.
P.S. If anyone is interested, I can expand on my modification description with more details and even some diagrams and pictures. Just let me know.
Reason: Removed reference to K1 ii and K3iii. They have the original plug.
