Hi!
Originally posted by jcdoss First, how has your tripod held up over the past 18 months?
It has held up just fine. It's not my main tripod (that would be the Peak Design Travel Tripod) but my son uses the K&F frequently. No sign of degradation on it, it works the same as it did on day 1.
Originally posted by jcdoss Would you still recommend it?
I have the same opinion about it, which is to say it's excellent for the price you pay. It's better than it should be at this price point, but it's still a moderately priced and lightweight tripod. If you have reasonable expectations, it will serve you well.
Originally posted by jcdoss Also, what do you think about its suitability for the larger lenses (3kg, 4kg with camera) I intend to use on it?
You shouldn't have any problem. I would recommend the same precautions as with any other light tripod: use the hook to stabilize if doing long exposures with heavy lenses, don't extend the center column unless you need to, don't tilt the head too much with heavy loads to preserve balance. With that in mind, the tripod will serve you well.
