I've had some time to experiment with the BA225 tripod from K&F concept (amazon link:
amazon.com : K&F Concept 61?tag=pentaxforums-20&" Carbon Fiber Camera Tripod, BA225 Professional Lightweight Compact Tripod with 360 Degree Ball Head, Quick Release Plate, Detachable Monopod 8KG Load Capacity for SLR DSLR Camera : Camera & Photo and I got a 10% coupon : KFCUS006 ).
This being me, and liking to be thorough, here's a mini review of it:
The tripod ships in a nice case, solid and roomy enough that it's easy to get the tripod in, without being too large:
The tripod itself is a fairly typical travel tripod. The colorway is cool (my children love it!)
The legs flip up for storage and down for use, as is usual
One nice thing, not always seen with such tripods (looking at your Sirui T-025x!) is that the center column can go down, to minimize vibrations
It can extend in two sections although I wouldn't advise to use that, again because of vibrations
The tripod head is again fairly typical, rather small since this is meant for travel, but with a panning base and an easy to adjust friction control
The base plate is larger than what I'm used to for such tripods, which helps somewhat with stability. It has position markings (in addition to the ubiquitous buddle level) so you can do some fine adjustments with the plate:
Something not found on every travel tripod (but not uncommon either) is a detachable leg which, coupled with the center column, can turn the apparatus into a monopod
The legs are nicely made of carbon fiber, and are truly lightweight. The last leg is somewhat small (not unexpected), so for very long exposures it might be better not to use it. For group photos or any situation where the exposure remains reasonably fast, it will do well
There are three positions for the legs on the spider. You have to lift the lock, adjust, then push it down. I would have preferred it to be siring-loaded but that's not a biggy. The spider has an accessory threaded hole to mount an extra accessory, something normally seen on much more expensive tripods.
There is of course a hook at the bottom of the center column
Now, the big question : how does it perform?
Keeping in mind that this is a $130 tripod (minus 10%), admirably well.
I regularly use a Peak Design Carbon Fiber tripod. It costs 5 times as much and even though I love it, I can't in all honestly say that it performs 5 times better.
The K&F Concept tripod is light, relatively compact, easy and straightforward to set up, nicely featured and works. From my time with it so far, it has proven stable, but I try to use my equipment within the range of what I expect it to do. I don't expect an inexpensive travel tripod to perform well for multi-minutes exposures, so I didn't try that. I expect it to hold my camera steady in normal use, and it did.
The legs lock via rotation knobs (twist knobs). These work well. The movement of the legs isn't as perfectly fluid as I'd wish, there is the tiniest bit of friction. That's where the price cutting shows, but it's no big deal. The center column does not rotate when lifting it, there is a padded leg (the one turning into a monopod), the camera plate is wide and grippy, all these things are clear positives. It is of course Arca-Swiss compatible.
One thing I might change is that the top plate is a bit large, preventing the full closing of the legs except if it's perfectly positioned. Also, the legs are quite far away from the center column, resulting in empty space. Not a problem for many, but since using the Peak Design tripod I'm sensitive to that. It should be possible to make the whole tripod more compact.
Again, for a $130 tripod, I have no true complaints. You often get what you pay for, this is true with tripods, but there is also a matter of diminishing returns. The BA225 works well and is reliable. It does not disappoint me.
