11-30-2008, 10:40 AM   #1
Vivitar 285hv
I own a Vivitar 285hv and a istD. The flash works great on the hot shoes. Since the istD does not have a pc sync connection how can I use the flash on a bracket attached to the camera ? I have seen various hot shoe connectors advertised. Which ones would work and can I use the pc cable that was supplied with the flash with them?
Thanks for any suggestions... Charles1
11-30-2008, 11:21 AM   #2
Venturi's Avatar
You just need a hotshoe adapter that has a female PC socket on it. And then yes, you can use the 285's sync cable.
Like this: FlashZebra.com: PC to Flash Hotshoe Adapter (Item #0065)
12-01-2008, 06:13 PM   #3
Big Dave's Avatar
To connect to the cameras flash termal, you need an adapter with a normal cotact on the bottom of the shoe, not a 1/4-20 socket.
Dave
QuoteOriginally posted by Venturi Quote
12-02-2008, 11:10 AM   #4
Thanks Dave, what about using the Sonia wireless remote ? Have you tried that product ?
12-03-2008, 09:09 AM   #5
Big Dave's Avatar
Charles,
No, I haven't. I just use a Nikon hotshoe adapter to allow the use of the 285 on a bracket. This is necessary when using the flash for verticl shots. I plan on doing some more experimenting in the future.
Dave
QuoteOriginally posted by Charles1 Quote
12-03-2008, 09:26 PM   #6
res3567's Avatar
How you researched the possibility if the flash damaging the camera with a high sync voltage?
12-04-2008, 06:31 AM   #7
The Vivitar 285hv is low voltage (designed for newer digital cameras)
Charles
12-05-2008, 08:35 AM   #8
Big Dave's Avatar
Charles, The Vivitar 285's have been around for quit a while. One was reported to read 350 volts on the flash trigger voltage site. I would check any used units with a meter, before using. Better safe then sorry.
Dave
Photo Strobe Trigger Voltages
Charles
12-05-2008, 11:17 AM   #9
Ratmagiclady's Avatar
It's true, the 285HV has been reissued with a lower trigger voltage, it's unclear how many of the older ones (like mine) are in a safer range. If you didn't buy it new, (and maybe even if you did) ....*test.*
AFAIK, there's no way to tell just by looking, which you have.
Some, as I recall, had a grey back panel rather than a black one, ...not sure what that may signify.
Non-HV 285s, and, unfortunately, 283s, are right out. Those can trigger more like that 200 or 300 volts, cause they didn't need to isolate the flash circuit from the trigger.
12-05-2008, 01:48 PM   #10
Big Dave's Avatar
Lady,
Some newer 283 and older 285's like mine have low voltage. My non-HV 285 has 7.5 volts and my old 283 has 250 volts. I always test first.
Dave
QuoteOriginally posted by Ratmagiclady Quote
flash, istd, pc, tripod, vivitar
For Sale - Sold: Vivitar 285HV (US/CAN) woof Sold Items 11 10-03-2010 07:05 AM
Vivitar 285HV on a K-x? MsFabCee Troubleshooting and Beginner Help 1 09-12-2010 01:50 PM
Vivitar 285HV oldjohn Pentax Camera and Field Accessories 3 04-21-2010 05:37 AM
Vivitar 285HV problem VF-19 Pentax Camera and Field Accessories 4 10-08-2008 08:14 AM
vivitar 285hv. Yes or no? skaktuss Pentax Camera and Field Accessories 11 10-17-2007 04:46 AM
All times are GMT -7. The time now is 10:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
