Hi!
I had the change to test the magnetic filters from K&F Concept earlier this summer. These filters require a thin magnetic ring to be mounted "permanently" on a lens or lenses, and then when you want to mount a filter, it attaches instantly and magnetically. You can read more about them here:
Speeding Things Up: K&F Concept's Nano-Series Magnetic Filters - Light And Matter
There are a few companies making such filters. Freewell is possibly the best-known, their products look excellent, but maybe with a slight warm cast. Kenko's products are less widely distributed, but also good. The K&F Concepts filters are actually the best of the three optically, based on my tests (no effect on sharpness and no colour cast). They're also the least expensive. They even let you use your original lens caps, something Freewell doesn't allow.
At first, however, the lineup was more limited, with only a polarizer and ND1000.
Recently, they released an ND8 and ND64, but maybe the most exiting aspect is that they offer those two filters with a magnetic lens cap. I decided to try them (plus it gives me more mounting rings!)
Me being me, here's a short opinion piece about them.
The filters (both ND8 and ND64) come in clear plastic case.
Inside the case are three items: the filter itself, a mounting ring, and a lens cap.
The mounting ring is described in the article I linked above. Essentially, it's a very thin ring that you leave on your lens at all times. If you have several lenses with the same diameter, you can swap between them easily but you need a ring per lens (the PL+ND1000 kit comes with a ring and a UV filter which also acts as a mounting ring).
The new filters are exactly similar to the previous ones, and I'm happy to report that they're optically just as good.
The cool aspect of this kit (beyond the extra options of the new ND values) is the lens cap.
It's VERY thin, solid metal, frankly good-looking, and serves a dual purpose.
First, it can mount magnetically over filters or directly on the mounting ring (that's the best way to use it IMHO). But it's also threaded, so it can also screw on a lens (without the mounting ring). It then acts a bit like some of the DA Limited caps (for instance on the 40mm). I don't see myself using that, but it's there.
When mounted on a lens, it shows a very slim profile, and attaches quite firmly (almost too much so, until you get the knack of removing it).
The filters can easily stack, along with the cap, and because they're thin, it helps with vignetting or dark corners.
As you can tell, I REALLY like those. They seriously have no real drawback, and make it much easier to use various filters. With my wife and kids I can't spare the time ti fumble with filters, screw, unscrew, drop the PL when trying to mount the ND, etc. With the magnets, it's instant. Many of my lenses use 67mm, so I can use them on each. I have a Revoring fitted with a mounting ring, and use that on my smaller diameter lenses.
I've used filters from many brands, Irix, Hoya, B+W, Heliopant, Optex, Tiffen, and in particular regarding the polarizer this one from K&F is, seriously, the best I've used. No colour cast and no sharpness degradation. That company might not have the recognition of some other brands, but they appear to be just as good.
Here's the link to what I got.
https://bit.ly/2Zb5m3G https://www.amazon.com/stores/page/592896B7-A7FC-4D38-841D-56EA963692C6?chan...netic%20filter
They also sell on Amazon, and they now appear to offer the CPL, ND8, ND64 and ND1000 alone (with the cap) in addition to the CPL+ND1000+UV kit.
