Originally posted by Lowell Goudge Lots of contradictory needs
Fit in carry-on is thr worst combined with any other need especially strong and stable
Low to the ground and no center column as a reversible center column is the means to get it.
You want independant legs I think
Light but able to carry / support 4 kilos minimum
Moderate cost I can see the head alone eating 50% of your budget
I wish you luck
Valid points Lowell... I guess I'm not super sure what I'm looking for exactly.
Carry on - at first I was thinking this would be convenient - avoiding checked bags when flying with gear, but I think this may be more hassle than it's worth, and I suppose checking isn't that big of a deal.
Low to the ground - I was meaning legs splaying out without having to fiddle around reversing columns - I think it's just simpler not to have a centre column at all, if it can be avoided.
Light weight... what does light weight even mean? I was thinking something not much over 5lbs - maybe that's not 'lightweight'?
I'm strongly considering just going with the Chinese tripod route and then taking the time to write a proper in depth review once I get it and use it a bit.
Maybe the Artcise (Innorel) AS80C - seems to have quite attractive specs, especially for the price (under CA$250).
It's a 4 section tripod without a centre column (leg widths of 32.5, 29, 25.5, 22mm), extends to 63.8" and down to 5.5" with legs splayed out, folding to 22.8" so meeting most of the requirements as well as having the bonus of a levelling head.
It gets quite favourable Amazon reviews and on Youtube too - so does it's bigger brother, the AS90C, but I'm thinking that's overkill for my needs.
Would this support the 150-450 solidly - that is the real question, reports seem to say that it should.
And if I were to go this route, what type of head should I get?
Initially I was saying a ball head, which I think is probably the most versatile for what I shoot being landscape and wildlife - but open to hearing suggestions... Do I go the Chinese Artcise head as well - see how that does for a complete 'cheap' tripod system overview?
More ideas and more questions...
