11-10-2021, 12:19 PM   #31
StiffLegged's Avatar
I shall watch your experience with interest, the levelling bowl looks a useful feature!
11-10-2021, 06:10 PM   #32
K2 to K50's Avatar
QuoteOriginally posted by StiffLegged Quote
+1.
I am regretting not forking out the extra for the carbon fibre version of the tripod I bought(Vanguard Alta Pro 2+ 263AP Aluminum-Alloy Tripod Kit withAlta PH-32) a couple of years ago. Especially as I have since acquired the Monster (150-450mm).
That gymbal sounds heavy. I am still debating the worth of some sort of fluid head.
Your thoughts on your new system after a few field uses would be of great interest.
11-11-2021, 08:01 AM   #33
bertwert's Avatar
It seems to work... haven't been out much, but neat.
QuoteOriginally posted by K2 to K50 Quote
+1.
As I said, not much use right now, I did go down to the river but all the eagles have left with the cold... I think this Jobu gimbal suits the 150-450 really well - if you decide to pursue one, get the 'deluxe' version however (more distance from tray to pivot), as the 150-450 has a tall foot and we need to attach a plate rather than use a replacement foot. And even then it's about a 1/4" above perfect balance, but this isn't a problem if you leave a tiny bit of tension on the pivot.
As far as weight, it's really not heavy at only 1.5lbs, by comparison a Wimberley gimbal is just over 3lbs (and bigger obviously, but I'm not seeing any advantage to having it unless you have a 500/4 or larger you use as well as the 150-450). If you're concerned about weight, I'm not really sure a fluid head would be the way to go for this, as I would think adjustable drag would be a must, the smallest (and cheapest) offering that are the Manfrotto 502 at 3.7lbs and the Benro S6 at 3.6lbs
Besides, the 150-450 + KP combo looks pretty at home on the Jobu. You can also see the levelling ball in use here:
bit, budget, column, head, kp, time, tripod
Novice Light Meter Musings Cont'd (when using Live view ) rml63 General Photography 6 01-22-2020 07:35 PM
Philosophies/Musings Of Improving As A Photographer aikilink Photographic Industry and Professionals 12 09-17-2018 06:56 PM
Philosophical musings on LBA (with humour) pathdoc Pentax SLR Lens Discussion 15 08-16-2015 03:25 PM
I got another lens today and other musings alamo5000 Pentax SLR Lens Discussion 11 12-15-2012 01:47 AM
Really random telephoto lens musings Marc Sabatella Pentax SLR Lens Discussion 50 04-26-2009 09:19 PM
All times are GMT -7. The time now is 05:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
