10-14-2021, 08:17 AM   #1
Tripod head mount is misaligned
I just purchased a new tripod and head from B&H (FieldOptics Research MicroLite FT-5021A Aluminum Tripod and FieldOptics FPH-200 Pan Head). When the head is mounted on the tripod, the head plate is not parallel to the tripod plate:
Name:  2021-10-14 10.33.36.jpg
The difference is 1.2 degrees.
The problem seems to be the head, and not the tripod. I measured the angle between the tripod's plate and screw (after straightening by the plate), and it seems exactly 90 degrees.
Is this something I can fix or I would need to send it back to B&H? I can see three screws on the head's plate. Could they be use to alight the head's plate, or they just hold the plate together?
Name:  2021-10-14 10.48.37.jpg
Also, what is the purpose of this small screw on the tripod plate?
Name:  2021-10-14 10.29.20.jpg
10-14-2021, 08:35 AM   #2
Not a Number's Avatar
Send it back. There's no guarantee those hex screws adjust the alignment. My Bogen/Manfrotto tripod head has similar screws to adjust the pivots and I find it impossible to adjust it so the head rotates with an even amount of friction throughout the 360.
You have to make minute adjustments to all three of the screws. Screw the head on to check. Unscrew, adjust, screw back on. Rinse and repeat. Maybe you'll get lucky or most likely you'll make it worse. The manufacturers must have some sort of rig to help during assembly.
If you ask me, it isn't worth the time and frustration when you can send it back for replacement.
10-14-2021, 09:03 AM   #3
Give it back, even if you manage to fix it, you may avoid future problems.
10-14-2021, 09:58 AM   #4
To answer your question about the screw on the tripod plate - you can tighten that to lock the head in place from loosening/unscrewing from the tripod.
10-14-2021, 10:36 AM   #5
Those screw threads are filthy. Clean them, and clean the socket in the base of the head, as there may be metal shards in there from tapping the threads that are causing the problem.
Then if you still have the problem, send it back. It looks poorly machined.
10-14-2021, 11:41 AM   #6
Thank you all for the suggestions!
QuoteOriginally posted by ProfessorBuzz Quote
This dust feels like rubber, not metal shavings.
10-14-2021, 07:11 PM - 1 Like   #7
Is the head fully tightened down to the base? If it is and still misaligned, I would call B&H. I'm sure they will take it back and make things right. Best customer service of any company I've ever dealt with.
10-15-2021, 05:20 AM   #8
You might also call the manufacturer.
10-16-2021, 05:20 AM   #9
To me, it looks to me like an increase in budget is in order. Going cheap only sets yourself up for disappointment.
For a tripod, may I suggest that you consider…
https://youtu.be/_cR71IbnBqc?t=496
For a ball head…
Enjoy the season… M
10-27-2021, 12:56 PM   #10
UPDATE:
B&H replaced the tripod head, but I was slapped with another round of "Duties & Taxes" by a brokerage agent, even though I paid them to B&H. B&H response was basically "not our problem". Beware of cross-border exchanges.
degrees, head, plate, screw, tripod, tripod head
Pentax 67 -- ISO wheel misaligned? aeraym Troubleshooting and Beginner Help 5 05-11-2021 09:36 AM
K5 sensor misaligned! can I fix it myself? shyrsio Pentax DSLR Discussion 11 12-17-2019 05:11 PM
Rokinon 24mm f1.4 factory refurb = misaligned optics DeadJohn Pentax SLR Lens Discussion 5 10-09-2018 03:52 PM
K-7 horizon misaligned? starbase218 Pentax DSLR Discussion 12 02-16-2011 01:16 PM
Misaligned/Leaning Images of People (Photo Fundamentals) stewart_photo Photographic Technique 30 10-17-2007 06:33 PM
All times are GMT -7. The time now is 11:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
