11-07-2021, 05:00 PM   #1
Tripod head with sticky tilt
I have a 3 way Monfrotto tripod head, model MH804-3W which has a sticky tilt motion. It jumps (moves too much) when I try to do a fine adjustment.
It can be frustrating!
I would welcome any suggestions on how to fix this.
Thanks,
Bill.
11-07-2021, 05:06 PM   #2
Wheatfield's Avatar
QuoteOriginally posted by bill.mc Quote
Thanks,
Bill.
Manfrotto is famous for rough, badly finished castings. Take the head apart, polish the castings until they are baby bottom smooth, and then reassemble the head. Use a lube like TriFlo, which is a Teflon based lubricant on the moving parts.
11-07-2021, 05:27 PM   #3
Not a Number's Avatar
You need a good damping grease:
11-07-2021, 07:17 PM   #4
Thanks for your replies.
Looks like I will have to pull it apart.
If I cannot source a teflon based grease, are there any alternatives (like silicon or lithium based) that would do?
11-08-2021, 06:26 AM   #5
UncleVanya's Avatar
Try a fishing shop. Drag grease is used in maintaining reels.
11-09-2021, 01:53 AM   #6
chrism888's Avatar
Graphite, i.e pencil lead can be a good dry lubricant for poss use in this instance
11-09-2021, 10:14 AM   #7
Wheatfield's Avatar
Go with the drag grease that was suggested above. Triflo will make things super slippery, drag grease will make things run smoothly but will provide a little damping to movement, which will make careful positioning possible.
Also, don't forget that with Pentax you have the composition adjust tool built into the camera. This is a great tool for dialing precise composition.
11-09-2021, 01:04 PM   #8
Here's the Australia office of Nye Lubricants. They don't have the Nyogel PG-44a (used in the videos) listed but you can contact them to see if there is a dealer that carries it or can special order it for you. Tripods is listed as one of the applications on Nye's website.
There's some sellers on eBay Australia that have the Nyogel 767a damping grease but that only has an NLGI index of 3 vs 5 for the PG-44a.
11-09-2021, 01:55 PM   #9
I think I have some reel grease at home, as well as some very fine honing tape.
But I have just arrived in New Zealand, so will have to source something locally. I should have addressed this problem earlier!
Will look out for some drag grease, I was also thinking maybe something from a bicycle shop might do the job if the first option isn't readily available, or try the pencil option...
Thanks for all the suggestions.
head, tilt, tripod, tripod head
For Sale - Sold: Manfrotto 055XPROB Pro Tripod with 804RC2 3-Way Pan/Tilt Head Curbster54 Sold Items 2 11-16-2016 11:54 AM
For Sale - Sold: 3-Way Pan/Tilt Tripod Head - Manfrotto 808RC4 (Worldwide) Ole Sold Items 3 01-19-2011 07:10 PM
pan-tilt head vs ball head raider Pentax Camera and Field Accessories 9 11-02-2008 09:13 PM
All times are GMT -7. The time now is 11:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
