I’ve had good success recently with some K&F Concept products (namely their magnetic filters and their K to E adapter, which I’ll comment later when I have more experience with it).
I wanted a versatile backpack, to be used by my young son for school and photo (he’s interested in my hobby, that’s cool!), so I decided to give their roll-top backpack a try. Here’s my take on it.
My first impression is that the backpack is surprisingly well-made. The fabric has a sleek feel, and even though it’s hard to tell without using it for a long time, it doesn’t appear cheaply made. The “camo” pattern on the fabric is more discrete in real life than on pictures and looks good even if I prefer smoother textures in general. The orange accents (and orange interior) contrast nicely. There's an included rain cover. and the fabric itself is waterproof.
The bag is a “roll-top”, something which I generally like as it makes it easy to expand the volume as needed. In this case, it’s partially a “fold-top” also since there is no Velcro to hold the roll in place, so it has a tendency to unroll. Having the top partially filled puts some tension on the roll, and helps keep it better in place. Also, the top attachment point of the front buckle is fixed, so it the top is close to full, it will be hard to attach the buckle. The buckle does have a long strap, so small to medium fills, which are more likely to occur, won’t cause problems, it’s the front section which expands towards the back.
That buckle is a “cobra buckle”. It’s metal, slightly heavy, and a pleasure to use. It adds an element of class to the backpack, as it’s often found as an (expensive) option on fancy backpacks.
To the front are two general-purpose small pockets.
One of those is RFID-protected so you can store cards or other items in there with confidence. Often, backpacks offer one larger pocket, here the two smaller ones have the advantage of being thicker than the usual.
On one side is the standard water bottle / tripod sleeve, with a stabilizing strap at the top so taller tripods will fit.
The back shows nice shoulder straps, well padded and standard-issue, straightforward adjustments.
The shoulder straps can be detached at the bottom, maybe to stash them behind the luggage pass-through for easier storage?
The back panel has ok padding, two sections in the lower area and one at the bottom. This creates good ventilation channels but it’s hot a hiking backpack!
When unrolled, the top is pretty tall.
It’s closed by a zipper so even if one goes overboard and fills it up completely, it’s still secure.
There is a thickness to the interior lining, even in the top section, that gives an added sense of security. Towards the bottom of the bag (only reachable from the top) is a padded laptop sleeve. The bottom of that sleeve is padded for protection. There is no back access to quickly reach the laptop, it’s done via the top.
On the side opposed to the water bottle pocket is a side access for camera gear. That access is rather unique.
The access panel is held closed by two vertical zippers joined by a big handle. The opening is thus wide and easy to access. The downside is that the top of that panel is not closed, just covered by a flap.
The interior of the panel holds two pockets, labeled for batteries and memory cards. We see the bottom of the laptop sleeve, and the padding.
Users are not forced to use the backpack for camera gear, it can be an everyday bag. There is, however, a sliding camera cube.
This cube can be taken completely apart. It’s made of thin and stiff panels; most of the protection comes from the bag’s padding.
Assembling the cube takes some guesswork as there are no instructions. Looking at company photos, it’s meant to be held in place via the supplied elastic band.
There are two long and two short dividers, giving options for subdivisions. There is also a kind of cover, more flexible and with more padding. This helps separate the cube from the rest of the bag when filling it from the top.
The cube must be seen as a “tray” coming out of the backpack. It’s possible to leave one side “open” and have quick access to the camera that way, pulling out the cube to reach other items inside.
All in all, I like this bag. It looks good, is well made and has many higher-end features. It’s not a copycat of other products. I’m not quite convinced about the design of the camera cube, at least for my use case, and reaching the laptop compartment requires unrolling the whole top; those are the two weaker aspects in my view. For the rest, this is a solid product, and much less expensive than some other everyday bags out there.
For the record, it'S this bag:
https://www.amazon.com/dp/B084G2RVY7?maas=maas_adg_4D0AEB3CC1E620D54D86813D8..._=aa_maas&th=1
