Originally posted by shyrsio So it there was a way to dictate the coordinates to the Astrotracer so that it could then do it's magic it would be perfect...Or am I missing something?
I don't think there is a way. As mentioned before, do you not only need your current position, you also need the direction the camera is pointed to (the compass in the phone is probably not accurate enough, even if you have a way to read out and transfer the needed data to the camera).
I guess it would be much easier building a barn door tracker instead.
