G'Day,
I am out of practice with my photography over the last couple of years, so please cross reference anything I say with other comments here and some research on the interwebs.
The first filter set I used was a Cokin square filter kit. The kit came with a frame and three Grad ND filters. The adaptor rings I bought were for the lenses I was adding them to which were from memory 67mm and 77mm. The benefit of a square filter system is the adaptor rings are relatively cheap which means you can swap the filter kit between different lenses despite having different filter ring sizes.
I have used the same Cokin square filter mounting system with a Singh Ray Reverse ND Grad filter. A reverse ND Grad is a good option to consider for landscapes particularly any sun on the horizon aspirations.
I also have a Nisi square filter set up but this was to use with the 15-30 and requires a different mounting system to attach to that lens as opposed to a filter ring.
Square filter considerations:
- You carry them separately as they can't just be screwed onto the front of a lens like a circular filter. Potentially will take up more space and therefore less convenience.
- Can produce more issues with flaring as there's no scope to add a lens hood.
- Have the potential for greater flexibility compared to circular filters as you buy the range of filters you want and the filter rings to fit each of your lenses. Ring mounts are one of the least expensive parts of the square filter kit.
- Can have issues with vignetting if the wrong set up is added to the wrong lens. This is usually an issue with wide angle lenses. For example some mounts can take three square filters others only one which assists in managing vignetting.
- Grad filters are really easy to use as you can slide them up/down to match the composition/horizon etc
- Square filters come in different sizes, don't buy anything larger than you need to as more size = more cost.
The circular lenses I have include Hoya, Singh Ray, Nisi and B&W.
I have circular filters from 49mm up to 82mm using the lens filter thread and I have a CPL for the 15-30 that uses the different mount around the body like the Nisi square filter set.
I've found vignetting with circular filters with wider focal lengths however circular filters are made in a 'standard size' and a slim size to reduce the likelihood or at least the severity of the vignetting on wide angles where it's an issue.
Circular filters can be used in conjunction with a square filter set. Be careful again of flaring and vignetting.
Circular filter considerations:
- Need to match the filter size for your lenses as you've mentioned already, but consider a larger size and step rings. For example you can fit a 77mm filter on a lens with a 58mm thread by using a set of step rings. Step rings are cheap and will interfere with lens hood use but could provide an inexpensive solution to manage different filter sizes.
- I leave CPL's on my lens all the time so they're always with me. I also carry a filter case to remove it if I need/want to.
- CPL's can produce uneven skies on wide angle lenses.
- Not seeing much positive talk about variable ND filters on the interwebs but as I don't have any won't make comment beyond recommending you check for reviews of products before purchasing.
To wrap up before I write an even bigger novel, I recommend you consider a solution for a filter kit using both circular and square filters to suit what you want to do. I like large stop ND filters, grad & reverse grad ND, and CPL. I try to use a filter only when I am after a specific look or in certain conditions to help manage the light.
Cokin I've found to have a warm cast, the B&W 10 stop a cool cast. The Singh Ray reverse ND was neutral (from memory as it's been a while) and the Nisi's have been a recent purchase so yet to see what they produce.
Hope the above can help with your decision about using filters.
Tas
