Originally posted by HoutHans Hi Disasterfilm,
Thanks for thinking and helping. I'm not sure whether this will allow me to expose longer than 30 seconds (which is what I'd like to do for astrophotography). The odd thing is that it works like a charm on the K-5 and refuses to work on the K-50. I'm now trying to tether the K-50 so that I can control the shutter from an external computer.
All the best,
hans
Ah, OK. 60-second intervals don't fit to that strategy. If you can be satisfied enough with 30s frames I'd say that'll be the way to go.
Here are some other things to try if you want to give your initial setup attempt another spin:
- Make sure you've switched your camera to manual focus mode.
- Be sure to disable automatic image review (you've probably already done this).
- Set the drive mode of the camera to "continuous", even if you're relying on the intervalometer timer (and not the burst-mode shooting).
- You may have a quicker recovery interval between successive frames with the camera set in Live View mode or the conventional viewfinder. I don't have a K-50 so I can't verify which.
