Originally posted by keith.s Transcend SDHC Class6 8GB cards are cheaper than chips on Amazon. I'm not sure if I'm missing something by not getting the Sandisk Ultra/Extreme. No complaints yet with the 2 x 8GB Transcends. Personally I dont't think our Pentaxes can really take advantage of the high speed cards
Hi keith,
Actually, My experience says that write speed can be important in at least one respect. I bought 2 ea Transcend 4GB SDHC Class 6 cards when I got my K20 in March. I didn't think much about the write speed, assuming that a Class 6 was apparently the fastest card spec that I could get.
I shoot birds, and since they don't take lighting into account when and where they choose to perch, challenges to correct exposure can be a bit of a problem, so I had gotten to rely on chimping quite frequently to make sure that I've got settings right. Since getting the K20, I've been a bit frustrated with the wait before I ccould see the review on the LCD after taking a multi-shot continuous burst. I figured that the large file sizes were the cause, and that long write times were just the price I had to pay when using such a high res sensor.
I recently used a older 133x Ridata 1GB SD card for a few shots, and noticed that after a 5 hot contiuous burst, there was a much shorter delay before I could see the display on the LCD. I tried the Transcend 4GB again, and had to wait about 4 sec while the orange "working" light flashed before I could chimp. Back to the 133x Ridata, and with the same 5 shot burst, it took somewhere between 1 and 2 seconds (measured "scientifically" with the "one-one thousand. . .two-one thousand" metodology). I did shoot the same scene with both, so variations in file size due to content was negligible.
I looked around on the net for some 4 GB Sandisk Extreme III, 20MB/sec and 30MB/sec cards from the same dealer and ordered one of each thinking that I could compare them with the same kind of test, however, when I got the cards, they were both the same (20MB/sec), so I can't comment on the faster spec cards, but the 20MB/sec cards are about as fast as the 133x Ridata, which is to be expected because 133x is roughly equal in spec to 20MB/sec. I've since found out that the Class 6 Transcend 4GB cards that I had been using were rated at about 7MB/sec, and this also seems to check out since they took over twice as long to write the test burst.
My conclusion is that the K20 is capable of taking advantage of at least 20MB/sec contiuous write speed. I remember reading a post somewhere by someone who tested the write speed of a K10, and it was over 16MB/sec.
I realize that with most users, this really doesn't matter, but I'm a happy camper with my new fast chimping K20. With the Sandisk Extreme IIIs, I can chimp about as fast as I had with either my DS or K10. This should make a bit of a difference in my shooting workflow for next spring.
Scott
