Originally posted by adamkean just wondering what the fastest shutter speed is you can get with a wireless strobe and radio sync on a k200d
In theory you can sync at 1/180 with the Cybersyncs, monolights and a K200D. The instructions indicate to step that down to increase reliability which I have found to be true with the limited testing that I've done. So it looks like 1/90-1/125 is the fastest you can go to insure that the strobes fire 100% of the time. From the instructions:
"The exposure time should be normally set one or two clicks slower than your camera’s maximum flash sync speed. For example, if your camera’s maximum sync speed is 1/250 second you should set it to 1/200 or 1/160 second.
While the latency (time from camera trigger to received flash command) of Cyber Sync is typically only 1/4000 second, setting the camera faster than its max flash sync speed with any manual flash unit will result in dark, unexposed areas."
ALSO: The issue with the protrusion of the test buttons outside of the case of the transmitter and receiver appears to have been addressed. While there may still be an issue of accidental activation of the receivers in a bag, the buttons stick out far less on my copies compared to the photos posted. While not perfect, it is an improvement.
I would recommend these to anyone wanting to go wireless for "basic" flash triggering. For advanced control of your monolights, there are better options out there. And, Paul C. Buff is working on an advanced transmitter for future release that will offer greater control of your lights:
AlienBees: The RadioRemote One Wireless System
