Originally posted by Ski Jumper I need a decent tripod for my k1 with da300 and A400. Anyone have any experience with Geehope on Amazon? Nice for $200. There's also a larger tube, no center column, without head for $214.
My other option is to save half the amount and get a perfect used manfrotto 3021b pro I found. For some reason, shared link only takes you to Amazon.
Geehope L330C+QP-44 Carbon Fiber Tripod $199
GEEHOPE B560C $214 / no head
-or-
Manfrotto 3021b pro with 488RC0 Midi Ball Head with RC0 RC SYST
$125 Mint condition
It depends on how are you going to use this tripod. If you are going to use it every day, or for any type of professional work, then I would go with the time-tested brands. A lot of these cheaper brand tripods come with excellent specs and good engineering, but if the material used in the manufacture is not up to par, then you might run into problems in the future. I'm not saying that all no-name brand tripods use cheap materials, but usually they had to cut corners somewhere to offer you these great prices.
Like I said this might not matter much if you are only going to use it occasionally, but for any heavy-duty use I would be wary. I'm not just saying that to dim your hopes, I went through a few cheaper brand tripods that were just not ready for prime time. For example I once had this tripod where one of the little plastic clips that keeps a tripod leg from being pulled out all the way broke after only 2 years of very light use. When I called the manufacturer for a replacement, they told me that Model was Discontinued and they no longer carried the part. That tripod was then rendered useless since one of the legs kept falling off. Another relatively cheap "Carbon Fibre" tripod I purchased($179), fared a little better, than the last one in that it lasted 3 years, but I did start to notice that the center column started to tilt like the leaning tower of Pisa ... Regardless, I kept using it, until one day I accidentally dropped it on some mud, yes mud and the part that holds all three legs broke in half ! Maybe there was a big hard rock under all that mud that I was unaware of ?
Another one of these cheapo tripods I purchased which I still have by the way, looked like a dream come true.i was "Beautiful", with sparkling paint and gold trim, it also came with a bag and spiked feet all for under $100. Supposedly it could hold 33 pounds, but when I took it out in the field, the legs would wobble like Jello under the slightest pressure(like pressing the shutter button).
Maybe you can find a camera store around your neighborhood where you can try the tripod out before buying. That would be your safest bet. Otherwise, read as many reviews as possible especially the negative ones. if it doesn't work out, you can always send it back
