Originally posted by yzuo Just realize that you might be referring to a different problem. If you can only set a maximum sync speed of 1/160 s instead of 1/180s, it is usually because the EV step setting in your camera is 1/3 EV instead of 1/2.
The problem I was talking about in my previous reply is the dark frame that appears in the bottom part when the shutter speed is set at 1/180s.
Originally posted by shiestmiester Ok, the 7000m has motorized zoom, adjustable power, bulid quality is supposed to be good for the price ($200 msrp, $50 on eBay). The only thing is the recycle time. I believe 0.3-10 secs. I'm only a hobbyist/amateur so I figured it wasn't a bad start. The remote I bought are V2s Cactus. Haven't recieved either but should be in soon. Definatley posting results. Anyway my original question was about compatibility of V2s and 7000m. The max trigger voltage for V2s is supposedly, but I haven't been able to find official voltage spec of 7000m. It's a film flash so I believe it to be higher. Read forum on dpreview.
Another question is V2s mods. I know you can increase range and change battery type, but does that also increase max trigger voltage? ( Cr2 to AAA or AA)
Also I'll postedsults on sync speed when if all arrives.
Thanks for the replys and I'm excited for the new equipment!!!
1/180(sometimes even 1/160) or faster on the v2s = no go, from previous experiences
regarding the battery mods, I dont know about trigger voltages being increased or decreased but I did make changing batteries cheaper for myself
2 CR2 batteries= $15-20
AAA battery boxes from radio shack =$2 each
hot glue gun =$found it in the couch, along with the money I used to buy the battery boxes
huge pack of AAA batteries from Costco =$13
one more thing about trigger voltage, a trigger signal is a trigger signal, I haven't had a flash that didn't fire except for an OOOOOOLD Vivitar 3500 that only took 2 AA batteries... other than that everything else fires fine.
