01-26-2009, 04:40 PM   #1
dadipentak's Avatar
Looking for Heavy Duty Tripod Suggestions
I'm expecting delivery of a 12lb (5290 gram) lens and definitely need to upgrade my tripod! It doesn't need to be light (back-packing is not in the cards)--just sturdy and moderate cost. Any suggestions?
01-26-2009, 05:42 PM   #2
Tom S.'s Avatar
Umm, it's not just the tripod. You can get a tripod that will handle 50 pounds and a head that will only handle 5. Many tripods and heads are sold separately, so you need to be aware of the weight rating for both.
You also need to determine what kind of head you want, ie., gimbal, ball, panning, etc. You also need to decide if you want quick release capabilities. I would suggest going to a camera store and looking them over.
Are you the person who bought the 1000mm lens on ebay last week?
01-26-2009, 05:51 PM   #3
Moderator Emeritus
I was also thinking about this subject. The tripod could possibly be a Survey tripod. I had one once and it was rock solid and heavy. I got it surplus at a place that sold to engineers and the like. Cost me all of $50 and it had a standard 5/8" screw thread. Those guys also use gimbal setups for their transits as well. A lens that big is better on a gimbal than a standard head. If you have a supply store for engineers and surveyors in your area, you might want to check out what they have.
You might also PM Wildman. He shoots with some very long glass and uses similar gimbal setups.
01-26-2009, 05:56 PM   #4
Moderator Emeritus
Here's a thread where Wildman post some info on his long lens setup.
https://www.pentaxforums.com/forums/451978-post10.html
And I thought my 6,000th post would be something significant .
01-26-2009, 06:40 PM   #5
soccerjoe5's Avatar
I believe even the Manfrotto 055 series will be enough (It can handle up to 15lbs I believe) which can be had for $150 or less. Very solid support and fantastic value.
As mentioned above though, the head will be much more critical
01-26-2009, 06:46 PM   #6
creampuff's Avatar
Gitzo Studex/Series 2 or Sries 3
01-26-2009, 07:26 PM   #7
dadipentak's Avatar
QuoteOriginally posted by Peter Zack Quote
Dude! We're talking about caring for a 1,000mm lens--how much more significant can you get?
Congratulations, btw--I appreciate your squandering that milestone on this.
Good guess, Tom, but KEH, not eBay.
01-26-2009, 07:29 PM   #8
Canada_Rockies's Avatar
QuoteOriginally posted by soccerjoe5 Quote
I have an 055B with the 0168 head. I am very pleased with it. My longest lens is only (!) 400mm. It has proven steady even with a 1.4X on it.
01-30-2009, 08:09 PM   #9
dadipentak's Avatar
Thanks for the commentary--it was very helpful.
By way of update, I went with Manfrotto: 055XB legs and 808RC4 Standard 3-way head. It's a pan head w/QR plate--it just seemed like a ball head could get wildly out of control very quickly with a lens this big.
I mounted the lens this afternoon and I'm pleased: it seems like a quite solid and surprisingly manageable set-up. I'll be taking some "shake-down" shots tomorrow--it'll be cold but (I hope) not too breezy.
01-31-2009, 01:31 AM   #10
QuoteOriginally posted by dadipentak Quote
Good choice. I have the same setup and you'll find it won't budge an inch even in strong winds. Mine came with quite a long two-part handle which got in the way at times, so I just unscrewed half of it and now it's perfect.
01-31-2009, 11:05 AM   #11
Wheatfield's Avatar
I don't know what you consider moderate, but I just took delivery of a big Feisol tripod and their big ballheaad. Reasonably light, and it has a huge load capacity.
02-02-2009, 11:32 AM   #12
I have heard of Feisol to be very good.
In your case, I would add a very firm head, such as the ones from Realy Right Stuff:
Really Right Stuff ... Your Camera Support Experts
or Wimberley : Wimberley Professional Photo Gear - Home Page
02-02-2009, 04:20 PM   #13
Ben_Edict's Avatar
No way. I never would use my 055 with such a load. I imagine that a lens of that weight will also excert considerable torque.
I would buy a used big Gitzo aluminium tripod (my old Gitzo Studex would probably be too small) . Alternatively wooden tripods would be a good choice, either dedicated photo modells by Berlebach, Wolf etc. or surveyors tripods, but these are really heavy (have one for a telescope...)
You will have more of a headache when it comes to a good tripod head for such a lens. I would either use a gimbal mount or a really good video head. Video heads are considerably cheaper than photo heads, as they have one axis less (2D instead of 3D), but heavy lenses are usually rotated in their mounting ring to switch between landscape and portrait format, so the third axis is not necessary. Otherwise the big Manfrotto gear driven head might be good choice.
While writing about video heads: a video tripod might also be a good choice - obviously not of the small variety...
Ben
02-02-2009, 04:37 PM   #14
Wheatfield's Avatar
QuoteOriginally posted by Ben_Edict Quote
I
Ben
I use a Zone VI tripod under a Wimberley head for my 600mm lens. I have no reason to think I might have too much tripod for this lens.
My 055 tried to collapse under the weight of my Pentax 6x7 and 105mm lens one day. I've been very wary of putting anything even remotely heavy on it ever since.
02-02-2009, 05:34 PM   #15
I use a Bogen 3421 fork mount on a Bogen 3246 tripod on everything from 500-1000mm and it works for me.
duty tripod, suggestions, tripod
Looking for Recommendations on a Tripod/Head that will hold a fairly heavy load? stl09 Pentax Camera and Field Accessories 19 09-11-2010 10:25 PM
mini tripod for heavy pentax platinum Pentax Camera and Field Accessories 3 11-09-2008 11:39 AM
Best tripod for a heavy telephoto lens? FastPhotography Pentax Camera and Field Accessories 10 01-23-2008 08:20 PM
All times are GMT -7. The time now is 08:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
