03-27-2007, 03:35 PM   #1
slip's Avatar
suggestions on portable back drop holder?
I was looking to invest in an inexpensive, easy to put together back drop holder for under 200 dollars.
size around 9-10 feet high, 12+ feet wide.
any suggestions much appreciated!!
randy
03-27-2007, 04:16 PM   #2
jfdavis58's Avatar
Perhaps...
Check this out. You will need something heavy to weight the 'feet'; I use the legs of old denim jeans. Cut at the knee, whip stitch one end, fill with dry sand, tie the open end with a small bungee cord. For an actual backdrop you can get cotton muslin, spray paint it or tie-dye it---there are several references elsewhere on the web. Of course, you could buy a real backdrop-but that's another couple hundred dollars.
03-27-2007, 04:47 PM   #3
slip's Avatar
QuoteOriginally posted by jfdavis58 Quote
thank you, Jfdavis58
are these types better then the colapsable "organ" type holders? around same price)
my wife needs the easiest to use and carry
thanks again,
randy
03-27-2007, 05:45 PM   #4
jfdavis58's Avatar
The side poles 'feet' fold and the center collapse to about 4 -5 feet long; the top piece telescopes down to about 4.5 feet when closed. They are very light and could be strapped together. Fits easy in a minivan, truck or large sedan. Length might be a problem with a compact car. Very easy to set-up and take down.
I don't know your exact size requirements; what you stated seems to be a bit large for portability. Maybe a hint has to what you might be shooting would help?
03-28-2007, 06:01 AM   #5
slip's Avatar
Thank you again for your help!
basically what we are going to is bring the backdrop holder/ backdrop with us to people's houses. not sure the exact size needs, but would need it taller then an adult with enough negative space above the head as well.
the vast majority of the shots are of children (3 kids max), but if some parent wants a shot with there child we would have to entertain that idea as well
randy
03-28-2007, 09:38 PM   #6
jfdavis58's Avatar
In home portraiture; nice idea. Full length/height stuff takes a lot of room--that's a big imposition on the client. Have you looked at the People Popper? Single stand, T bar, 6 by 8 feet reversible backdrop. Good for up to three people in a 2/3 or 3/4 length situation. The whole rig fits in a pair of small duffle bags. Fun part is stuffing the backdrop into it's bag--not folded just wadded and stuffed in--wrinkles are part of the charm. Several colors--you can buy the cloth as a standalone. Sometimes it is on 'special' and then you get a small folding posing bench-very nice!
drop, feet, suggestions, tripod
Sourcing a Cokin Z Holder lats Pentax Camera and Field Accessories 12 11-05-2010 11:44 AM
ghetto battery holder Gooshin Photographic Technique 0 08-19-2008 07:21 PM
holder is in the eye of the holder craftsmansky Monthly Photo Contests 0 11-18-2007 12:08 PM
Photobanks/Portable Drive Suggestions? smcclelland Pentax Camera and Field Accessories 25 08-20-2007 11:25 AM
All times are GMT -7. The time now is 06:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
