02-10-2009, 04:28 PM   #1
eyou's Avatar
Focusing Screen for K2000/K-M
I"m trying to get a focusing split prism screen for the k-m. I saw that focusingscreen.com has one for the k-m, but its ~$70. I'm trying to get one of those cheap ebay ones =) (can't see myself spending >$100 on such an entry level camera), but i havent seen any yet. Does the k-m share the same focusing screen as any of its other brothers in the product line? I noticed the k-m and k200d both have pentamirrors so maybe it would be the same fit? Thanks
02-10-2009, 11:58 PM   #2
I use one of those inexpensive Ebay screens and it is nice--large bang for the buck. If I were you, I would click on an Ebay link like this one Diagonal Split Image Focus Screen Pentax K100D K200D DL - eBay (item 200278871297 end time Feb-19-09 15:44:33 PST)
......and then opt to "ask the seller a question." I am sure the sellers of these things would love to find the answer to your question because it will bring them increased sales for sure. Tell them your camera make and model. One of the screens they already sell might even fit the k-m. Best of luck.
02-12-2009, 11:32 AM   #3
eyou's Avatar
thanks for the message... Km actually uses the same size screen as K100D , but it seems that the thickness is a bit different... so that need to be adjusted... we're not sure of the exact thickness yet...
best...
- jinfinance
hello dear,
we haven't it.
best regards!
- jiakgong
doenst look like it yet. The $80 for the focusingscreen.com is just too much for a $400 camera. guess it will have to wait
08-02-2009, 03:59 PM   #4
eyou's Avatar
I noticed that Jinfinance now has listed a k2000/k-m focusing screen. I just purchased one myself. I asked him to throw in some shims in case (b/c the reason it wouldnt work was incorrect thickness?), which he said he will but he says it should work fine.
I've been waiting for a focus screen for a while for the k-m/k2000 from a chinese vendor. focusingscreens.com has one for $70, and katz-eye has one, but i wanted a cheaper alternative.
I'll post again when i receive the item and test it.
08-02-2009, 10:52 PM   #5
LeDave's Avatar
Hey I'm looking forward to your testing once you get it!
08-05-2009, 07:43 PM   #6
res3567's Avatar
QuoteOriginally posted by Jewelltrail Quote
Hey Jewell!
I love my screen from jinfinance!
IMO it is the best of the inexpensive screens and thanks to you as to the reason I bought it!
08-06-2009, 06:38 AM   #7
LeDave's Avatar
QuoteOriginally posted by res3567 Quote
Hey Jewell!
It doesn't come with a tweezer, what exactly do you use and do to get the screen out and the new one in? Also what room do you swap it in, the restroom?
08-06-2009, 10:51 PM   #8
res3567's Avatar
QuoteOriginally posted by LeDave Quote
Mine came with finger condems. If you can gently pry it out with your fingers strapped with these condems, that should work. You may have to buy the plastic twezzers however if your fingers are to big and the screen is stubborn releasing itself from the frame. You can also try tilting the camera gently forward to pry it lose.
You have to be very careful as to not put any undue pressure on the frame assembly as it looks to be very fragile.
Yes a restroom would be ideal as long as it as dust free as possible.
Any room would suffice however.
Just make sure you take care to keep the screen from comming in contact with dust.
I set my screen on a lint free camera cloth prior to instalation.
And remmber the jinfinance screens may come with a trasparent cover on both sides to protect it. (mine did).
08-19-2009, 04:53 PM   #9
Hello,
I just picked up a k2000 from B&H and now want to get a focusing screen.
It sounds like you have screens from two different vendors. Did either of you notice a difference in brightness between your original screen and the replacement screen you used?
Thanks for any help you can provide.
Regards,
mteetank
08-25-2009, 09:50 AM   #10
eyou's Avatar
tho I ordered mine from jinfinance, my package came from New Hampshire? No condoms, no tweezers, and there was a defect on the screen. At first I was pretty happy with it, but then realized it is not truly accurate. When the picture is in focus, the split does not exactly line up.
When the prism says it is right, the focus is slightly closer than it should be. Can i add scotch tape or something to increase the shim thickness to make it work?
i was pretty disappointed with this purchase....
08-25-2009, 09:54 PM   #11
LeDave's Avatar
Does autofocus work with these jinfinance focusing screens? And eyou, you said that it's not truly accurate, does this mess with the autofocusing in any way?
08-25-2009, 10:31 PM   #12
WheresWaldo's Avatar
1. Yes
2. No
08-25-2009, 11:17 PM   #13
So this screen from "jinfinance" is not accurate, right?
I am in the same boat, I don't want to spend too much on this screen, so I am thinking about getting this one.
08-26-2009, 12:09 AM   #14
QuoteOriginally posted by grishazzz Quote
Incorrect.
Screen works fine. Only issue involves spot metering, not focusing!
08-26-2009, 12:38 AM   #15
QuoteOriginally posted by WheresWaldo Quote
Incorrect.
What do you mean? Please explain. Spot metering is not accurate when using this custom screen?
k-m, screen, tripod
Focusing manual lens with OEM focusing screen, is a split screen really needed? skid2964 Pentax Camera and Field Accessories 16 09-17-2010 02:54 PM
For Sale - Sold: Pentax Brand Focusing Screens and Katz Eye Focusing Screen K10D/K20D (Worldwid superbass Sold Items 8 03-26-2010 01:42 PM
For Sale - Sold: Minolta X-700 Focusing Screen (for you to cut your own split screen) frank Sold Items 3 09-24-2009 10:08 PM
Seeking advice on focusing screen (split screen) for K200D Ari Freund Pentax DSLR Discussion 8 07-31-2009 03:00 AM
For Sale - Sold: K100d and 18-55mm kit lens + split focusing screen installed + glass screen pr vanchaz2002 Sold Items 1 07-24-2008 07:09 AM
All times are GMT -7. The time now is 03:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
