I recently bought the Sunpak Pro 723B...cf tripod. The gitzo's or other top name brands were way out of my price range. This is a great step up from what I was previously using. I stand about 5'5" and with the K20D attached it is right at eye level without any extentions used. It's my first ballhead and carbon fiber, so I'm quite impressed. Bought it for 299.99 through B&H Photo.
Sunpak | Pro 723B Carbon Fiber Tripod with | 620-723-CFT-B | B&H
The Sunpak Pro 723B Carbon Fiber Tripod with Ballhead is a heavy-duty, lightweight, full size tripod that is designed for the serious amateur and working professional photographer. By using carbon fiber material for its leg construction, this tripod is about a third lighter then comparable conventional aluminum tripods. This tripod features three positions of leg spread for normal, semi-low and full-low angle shooting, and the split rapid center column detaches appropriately to access the full range of height.
The included heavy-duty ballhead includes a large quick release system, and features a double lock design, with tension control.
The leg materials are made of high-strength carbon fiber tubing commonly used in aerospace engineering, which yield exceptional stability for its weight. Carbon fiber materials are very shock and vibration absorbent, but still relatively lightweight.
• Neoprene Leg Grips
The top sections of the legs come protected with neoprene non-slip foam covers, for better handling in extreme weather conditions
• Retractable Hook
The retractable hook can be used to add stability with a sand bag or equipment bag
• Top-leg diameter of 28mm
